BIKELAND > FORUMS > ZX-14.com > Thread: Where to tap into coil wires for kill? NEW TOPIC NEW POLL POST REPLY
mark524
posted July 25, 2007 05:11 AM
Where did you guys tap into the coil wires for you air shifter kill box? I notice that under the tank there's a big harness. I'm guessing everything is in there. Seems it would be easier to tap in further back. I'm not very good at wiring. My kill box will be here today, just wanting some guidance in the right direction. Thanks.
mikebar4
posted July 25, 2007 01:16 PM
follow the wires at the top of your plugs. they will go to the left of your bike into a plug. what i did was cut the tape back to give you more room, and find the wires there. tap into them and cover them up with tape.. you should be set to go..
mark524
posted July 25, 2007 01:20 PM
thanks. I figured it out. Just wired in back under the seat where they go into the ecu.
fury
posted July 26, 2007 03:10 AM
Did you guys know u have a tip over switch on this bike?
0.24932408332825 seconds processing time
