BIKELAND > FORUMS > ZX-14.com > Thread: Speedo healer or Yellow box? NEW TOPIC NEW POLL POST REPLY
budwardo
posted July 13, 2007 05:41 AM
Need one. I heard from one company the speedo healer is having so problems? I have had them before with no troubles. Any experiences?
FasterThanStink
posted July 13, 2007 12:10 PM
Almost everyone here has used Speedo Healer with no problems.
That's what gets you.
posted July 13, 2007 12:16 PM
speedohealer... plug n play with harness adapter.
speedohealer removes speed limiter even with stock gearing corrected or not..
not sure about the yellow box.
both will mess with the gear indicator if you go way out on correction for big gearing changes though.
Xtremespeed
posted July 13, 2007 03:56 PM
Speedohealer is easier to connect.
Yellow box will accomplish the same thing.
Someone tell me how to derestrict with stock gearing and corrected speedometer. Maybe I misunderstood what you said, but I don't think it's possible. The only way I know to derestrict is to set the speedohealer to read slow.
You don't have to go way out on correction for the speedohealer to mess with the gear indicator. I have factory gearing, and speedohealer set at 7.5% and my indicator isn't right.
posted July 13, 2007 04:46 PM
it should automatically indicate 5th gear instead of 6th to the ecm when approaching 186 mph, and allow it to rev out in 6th gear no?
Mine is adjusted for 16 tooth sproket.
TJ
posted July 13, 2007 07:49 PM
Mine shows the correct gear all the time even after being adjusted for a 16T countershaft sprocket.
Xtremespeed
posted July 14, 2007 06:59 AM
I'd like to know the difference between yours and mine. Mine has never acted right since I put the speedohealer on. I can pull the clutch in and the gear indicator will read correctly.
I don't think the ecu will ignore the speed restriction when it sees 5th gear. I believe it's only based on speed, not gear position.
posted July 15, 2007 03:52 PM
bikes torn down , puttin on ohlins shock and track 6" arm , sprokets chain, stainless braided lines etc...
still waitin for Muzzy air shifter and N2O....
can't confirm right now....
chez
posted July 16, 2007 03:24 PM
I swear by yellow box, probably cause they're Australian....never had any problems....easy fit.
Chez
  Ignore this member    Click here to send Chez an AIM message.
0.23869395256042 seconds processing time
