BIKELAND > FORUMS > ZX-14.com > Thread: 200 Tire NEW TOPIC NEW POLL POST REPLY
MakennaEllen
posted July 10, 2007 02:57 PM
200 Tire
The ZX14 wears a 190 shoe; has anyone put on a 200 with the stock swingarm? Anybody know if it will fit?
hardcoremass
Powerhouse
posted July 10, 2007 03:01 PM
Yes, it will fit. If you do a search, you will find that it has been done before. The only concern was the handling...
pazx14rider
posted July 10, 2007 03:49 PM
yes a 200 will fit not that much bigger than a 190
posted July 10, 2007 04:30 PM
no comment
posted July 10, 2007 04:54 PM
a 200 size tire on a stock bike is a thing of the past...
If you want a big tire then get a 300!!!
Wheelie
Old Man
posted July 10, 2007 05:22 PM
what about a 200 Shinko at the strip? wee
BlackMagic14
posted July 10, 2007 06:38 PM
200 shinko= heavier tire and same size contact patch=slower!!!
TJ
posted July 10, 2007 07:54 PM
The ZX12R came stock with a 200 series tire. Most of us swapped it out for a 190 pretty quickly
snarleybill
posted September 08, 2007 01:06 PM
don't waste your money on a 200 tire on the stock width rim it is only .020 '' wider than stock.the equivilent o 5 sheets of paper.i put one on mine and checked it with a calipers and was highly disapointed,
don't take no wooden nickels
kc jr 54
Fat Guy
posted September 09, 2007 01:15 AM
What about a 180 shinko for the rear ? Is my thinking all wrong when i say it could give you more contact patch ? (then a 190)
posted September 09, 2007 04:55 AM
180 = less patch in the middle but better handling in turns
fastest-14
Fastest -14
posted September 09, 2007 08:02 AM
I have to disagree with you Steve. The 180 will have more contact patch in the middle then the 190 or 200 because you have a narrower tire on a rim meant for a larger tire, so therefore it causes the tire to spread out more in the middle to compensate for the width of a wider rim, also many guys including myself have gone to a narrower tire because of this and because it's usually a lighter at 180 then 190, less rotating mass, which translates into more HP.
ninjaboy311
posted September 10, 2007 10:27 AM
X2.
I've run the 180 three different times, and the 190 once, and the 180 had more contact.
Right now, I have the Michelin Power Race 180 'Soft Compund', and at 100 passes, it is stickier than anything I've ever seen before. My bike wants to rotate around the tire with 15 psi. Of course the track has got to be prepped pretty good.
100 passes and the tire still has lots of tread left. I was concerned that the Michelin may not last as long as the Shinko, but its proven to last. I think its because it requires very little burnout.
Saturday I was up to 18 psi, sitting at 69" wheelbase, and I couldn't launch the bike cuz it was hooking so good. Kept bucking off the line.
Nelson Taylor
posted September 10, 2007 10:57 AM
I am running a 200 Shinko on the strip.
Its been working all year for me.
posted September 11, 2007 05:34 PM        Edited By: stevewfl on 11 Sep 2007 18:35
"Right now, I have the Michelin Power Race 180 'Soft Compund', and at 100 passes, it is stickier than anything I've ever seen before. My bike wants to rotate around the tire with 15 psi. Of course the track has got to be prepped pretty good."
Thats exactly what I run on the track, tire warmers a must. I guess you burn it off on the drag strip to heat it.
The tire is so soft and gummy I can see my thumb print in it.
0.24324083328247 seconds processing time
