BIKELAND > FORUMS > ZX-14.com > Thread: Speedohealer Install Questions NEW TOPIC NEW POLL POST REPLY
dac
posted July 08, 2007 02:17 AM
Hey guys,,, After trying the search feature for a hour, because i know ive read about this before..i figured i just ask... Im installing a speedohealer on my 07 ZX14... i hooked up the wires into the harness the way i thought they should go... nothing....no LED flash.. question is... which colored wires go where... since the speedohealer colored wires dont match the stock color wires... in laymen terms this is what i have.... on one connector...stock colors are pink, yellow, black ...the speedohealer choices are white, red, black ..... the other connector...stock colors are.. pink, blue/yellow, black/yellow... the speedohealer choices are orange, green, black...... i tried this- pink to red, yellow to white, black to black the other connector i went with... pink to green, blue/yellow to orange, black yellow to black... i turned the ignition on (didnt start or move the bike).. went through the instructions numerous times....nothing... speedohealer light didnt flash at all..not once... any help would be appreciated..
  Ignore this member    Click here to send DAC an AIM message.
Xtremespeed
posted July 08, 2007 08:30 AM        Edited By: Xtremespeed on 8 Jul 2007 09:36
Stock ..................................Speedohealer
Pink ....................................Orange
Yellow .................................White
Black ..................................Black
Pink ......................................Red
Blue/Yellow .........................Green
Black/Yellow ........................Black
posted July 08, 2007 02:53 PM
sounds intuitive why didn't you get it the first time
blackbullet76
posted July 08, 2007 04:29 PM
Doesn't the healer effect the gear indicator? Says you're in 5th sometimes when you're in 6th?
BobC
posted July 09, 2007 02:28 AM
On the ZX-14's 3-pole speed sensor plug:
power = Pink
ground = Black with Yellow stripe
signal = Blue with Yellow stripe
dac
posted July 09, 2007 05:39 AM
Thanks guys ill give it a try,,,from what ive read as long as you dont change the stock gearing ...by more than a tooth... the gear indicator should be fine... The TRE is the one that mess's with the indicator... thats as i understand it
blackbullet76
posted July 09, 2007 05:51 AM
Oh ok. Well, that's why I haven't messed with my sprockets yet. I'll be getting me a 16 tooth soon then.
MasterBlaster
posted July 09, 2007 10:15 AM
16 tooth and S/H here and the only gear it messes with is 6th. It will initally indicate 6th, and then drop down to 5th. No big deal for me since it indicates all the lower gears correctly.....TB
blackbullet76
posted July 09, 2007 11:04 AM
Oh, well that's what I thought I read on here. I really like for my gear indicator to work correctly, but if going to a 16 tooth will help me at the track, I might go ahead and get one.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Xtremespeed
posted July 09, 2007 03:13 PM
Mine was affected and I have stock gearing. I notice it mostly in 6th, but it appears to affect 3-6. Never noticed it in second.
0.26185512542725 seconds processing time
