BIKELAND > FORUMS > ZX-14.com > Thread: Added a second radiator fan on the 14 NEW TOPIC NEW POLL POST REPLY
SciFiJoe
posted July 06, 2007 05:03 AM        Edited By: SciFiJoe on 6 Jul 2007 06:13
Looks like I should try photobucket. For now go here for all the pictures: http://picasaweb.google.com/SciFiJoe/ZX142ndRadiatorFanMod
I'll redo the photos tonight.
It was only the beginning of June when one late evening I was riding home on the 14 in slow moving traffic and there goes the temp gauge. Past middle, then just below H. What the He|| is going to happen in July or August in the afternoon? So it's off to the forum to find out what fellow salty balled riders are doing. This bitch really gets you hot between the legs Anyway it seems I don't have to worry about the 14 overheating until the stupid gauge starts to blink. Hmm, I don't like that idea. So I decide to add a second fan. It should fit. No problem right? Well it does fit but its a pain in the a$$ to do.
OK, first remove the radiator:
Now get the second fan (bought mine new on ebay for $50):
Remove the fan from the bracket, held on by 3 small screws:
Now take the bracket apart. Drill out the welded rivets and gently pry apart. You're going to have to mirror the brackets in order to get a left fan to fit on the right side of the radiator. That bracket with the sideways bend is a bitch:
I used some 3/4" aluminum square bar to make the top and bottom mount. I fits right in the channel of the radiator:
I fabricated the bottom bracket so that it would be the same distance up as the original bracket. I also made sure to leave a little space between the bracket and the radiator:
Here are the pieces welded. It may not be pretty but it works
Here's the assembled pieces on the radiator. Look closely at the top left mounting bracket on the new (right) fan. The good news here it that you share the existing center mount. The bad news is that this bracket has a bend in it that you have to reverse. Heat it up real good to bend it. I messed it up a bit but if I had to do it again I think I could do better. The bottom line is it fit.
Check the clearances before and after mounting the radiator back on the bike, you may need to add a washer or two to get proper clearance:
Finally the electric. The original fan is run off a 15 amp fuse. Running two fans off the same fuse would probably blow the fuse causing you to overheat and have a bad day. I chose to mount a paddle switch. I wired the positive from the battery to a fuse holder with a 15 amp fuse then to the paddle switch then to the blue wire on the fan. Then I took the black wire on the fan and soldered a small length of wire to it and I grounded it on the frame. I didn't take a picture of that but here's where I put the switch:
Now when the gauge gets to the middle mark I'll throw on the fan. The original fan will still operate as designed. It's been cool here on Long Island since I did this so I don't know how it's going to do in some real heat. I'll post an update in a couple of weeks.
White '07 ZX14, flies out, Brock's Gen 3, PCIII USB & Brock's map.
worm~hole
posted July 06, 2007 05:50 AM        Edited By: worm~hole on 6 Jul 2007 06:52
...I now know how to mount red "x"s ....its not coming up....
posted July 06, 2007 01:26 PM
"What the He|| is going to happen in July or August in the afternoon?"
If you have a Florida ZX14 such as myself and many others on this forum, nothing is going to happen when it sits in extreme heat :P
countersteer
Didn't read the owners manual
posted July 06, 2007 02:18 PM
scifi, where abouts on the island are ya? im out in riverhead.
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
BX-AZZAZIN
posted July 06, 2007 08:00 PM
Hey wats-up scifi. I live in the bronx and I definately felt the heat those days when we hit 90.
I was curious would you be willing to make a modified fan for me, let me know. I'll find a fan on ebay and pick it up.
whatever it 'll cost, i checked your pics great job. I definitely need it. well hope to hear from you.
Be safe keep it on two, or ONE...
posted July 06, 2007 09:31 PM
nice work! too bad this isn't installed from the factory
FasterThanStink
posted July 07, 2007 02:37 AM
That's what gets you.
Ojref
posted July 07, 2007 05:21 AM
I hope you painted that other bracket after you put it on!
THEMADKAW
posted July 07, 2007 06:23 AM        Edited By: THEMADKAW on 7 Jul 2007 07:24
i'm with BX! i don't like my fan running all the time. and this is the time of year i work the most. i'm more than willing to pay you for your R&D and labor to build a kit or do the mods!
if you'r interested just let me know!
otherwise guess i'll have to wait till winter.
BX-AZZAZIN
posted July 07, 2007 09:34 AM
+1 PLEASE HELP ME--I'M MELLLLLLTING!!!! LMAO
posted July 07, 2007 10:11 AM
nice work
raptor14
posted July 07, 2007 01:03 PM
Thanks for the info SciFiJoe. Hope you don't mind but I thought your instructions were important enough to combine the text and pics into a .pdf file which can be accessed using Acrobat Reader. Hopefully I captured your document word for word. It credits you with the creation of the document and provides a link to your original post. The .pdf file can be downloaded at:
http://members.cox.net/allengeo/ZX-14/Add%20A%20Second%20Fan.pdf
FasterThanStink
posted July 07, 2007 03:42 PM
Thanks Raptor14! That's awesome. Great work ScifiJoe. Mine could really use the second fan. There is going to be bidding wars for fans on E-bay now.
Bobs07zx14Black
posted July 07, 2007 07:15 PM
I dont see any pics....
Bob
JamesE
posted July 07, 2007 07:44 PM        Edited By: JamesE on 7 Jul 2007 20:45
Just a question, how about just turning another oem 14 upside down and fabbing the mounts on the rad to make that work? Looks like plenty of room, and it wouldn't be near as hard.
btw, nice work Joe
07 Plasma Blue ZX 14 Flies out Tsukigi slip-ons, PCIII, -2" rear
-1" frt, Heli's, Scorpio SR500i equipped
FasterThanStink
posted July 07, 2007 09:17 PM
Click on the link or download the PDF.
raptor14
posted July 08, 2007 05:41 AM
I'm wondering if the 2nd fan on the Concours14 will fit the ZX14 without modification. Anyone have any knowledge on this?
SciFiJoe
posted July 09, 2007 03:45 AM        Edited By: SciFiJoe on 9 Jul 2007 05:14
I'm in Farmingdale
SciFiJoe
posted July 09, 2007 04:14 AM
OK, now I've got the photo thing working but I can't edit my original post. Maybe you're only allowed a few edits per post? Whatever, here's the whole post with pics:
Photo Sharing and Video Hosting at Photobucket
Here are the pieces welded. It may not be pretty but it works:
SciFiJoe
posted July 09, 2007 04:56 AM
btw, nice work Joe
If it's upside down then the fan would hit the headers. At least Brock's header, probably the stock ones also.
icetee
posted July 09, 2007 08:45 AM
how much kooler is the bike running now with the mods?
fastestbusaaround
I eat Fish...
posted July 09, 2007 04:56 PM        Edited By: fastestbusaaround on 9 Jul 2007 17:58
Here's what I did...used only distilled watter and a full bottle of Redline. Now I'm running at between 1 bar below and 1 bar above the halfway point; this during stalled traffic at temps over 90. idling for over 45 minutes...and it never ever goes more than 1 bar over 1/2...
I had seen all bars light up twice last year in heavy traffic, but since I changed the mix to Redline and distilled, she runs way cooler consistently. I wonder if a 2nd fan would keep it at the halfway mark or below in the same scenario...but I don't really have issues with heat. I do notice that it takes longer to get to 1 bar below center than it did before in warmer ambient temps on the highway, but still runs much cooler in traffic. This is probably also due to less friction, as the engine now has 22k KM's on it, so that may have been a factor as well, but the mix made a big difference, no doubt about it!
FYYFF!!!
FasterThanStink
posted July 09, 2007 05:15 PM
Getting rid of the antifreeze will help cooling enormously as FBA found. In that case using Water Wetter is mandatory as the water pump needs a source of lubricant.
fastestbusaaround
I eat Fish...
posted July 09, 2007 05:35 PM
and anti-corrosion..which Redline does.
FYYFF!!!
0.22553682327271 seconds processing time
