BIKELAND > FORUMS > ZX-14.com > Thread: Kawasaki centerstand installed with Leo Vince 4-2-1 exhaust... NEW TOPIC NEW POLL POST REPLY
LeoVinceZX14
Thankfully...its paid for...
posted July 07, 2007 01:11 PM
Guys:
I just installed the Kawasaki accessory centerstand on my bike with no clearance problems for the full 4-2-1 Leo Vince exhaust I have on the bike. The stand weighs > 5 lbs and together with the LV exhaust weigh about the same as one OEM muffler bank (14 lbs). A $10 chromed bracket with a rubber damper is the "trick" part (see photo # 3).
Why do it? Way easier to lube the chain, do maintence on the bike and I take trips where you need to do this stuff in a motel parking lot or some gas station in the middle of nowhere...
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
posted July 07, 2007 05:53 PM
i remember when bikes came with these
87gtNOS
posted July 07, 2007 06:49 PM
I am at my Uncle's, and we're having a good laugh about that!!
Anyways, can you please post a pitcure of the stand 'up'?! Do you notice it under there?
01 ZX12R
LeoVinceZX14
posted July 08, 2007 04:05 AM
Stand up photos....
GT87NOS:
Here you go with stand up photos:I
'm not wild about the look from the left side, but the maintenance benefits far out weigh the look. Will be testing the ground clearance in the next couple of weeks to see whether that's an issue in the street. Hasn't been so far, but I have really flicked it over hard since the stand went on.
Ride safe.....
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
Boss69
posted July 08, 2007 04:22 AM        Edited By: Boss69 on 8 Jul 2007 05:22
Is this something the dealer has to order for you? Cost?
Did it come with the chrome stop?
Picking up my 14 tomorrow and would like to get one or order it.
Thanks,
Jack
'07 Blue ZX-14 Turbo (FOR SALE)
'07 Victory Jackpot Ness Edition (FOR SALE)
'04 EX500, for son and wife to learn on.(sold)
'78 Z1-R (sold)
'75 Z1 900 (sold)
LeoVinceZX14
posted July 08, 2007 05:14 AM
Centerstand setup....
Boss 69:
The centerstand is a Kawasaki part which your dealer will almost certainly have to order as I doubt its a stock item. Retail is about $200 depending on your area and dealer. The chome stop is not a dealer part, it was something my tuner had laying around in his shop and modified for this application. The stand bolts up with no issues for the OEM exhaust and wouldn't need the chrome stop if that is your setup.
If you are running a aftermarket pipe other than LV ask you manufacturer. I posted the centerstand photos believing others would want to do the same once they saw it in place. Based on my experience, your probably ok with the pipe styles that tuck in decently. The key area is clearance around the bottom rear shock mount where the chrome bracket is fitted and where the stand would come up in a level plane.
If you are in or near Florida I can put you in touch with my tuner for the chrome stop which includes a very slick rubber damper so the stand goes up without a sound.
Ride Safe.....
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
posted July 08, 2007 02:56 PM        Edited By: bigdtd on 8 Jul 2007 15:56
t-rex stands front and rear $85 on ebay
LeoVinceZX14
posted July 08, 2007 03:14 PM
Stands are cheaper....reply
bigdtd:
No doubt you can find stands cheaper than my install. I did it for mobility and convenience. I wouldn't be able carry stands on the bike on road trips.....
thx.
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
posted July 08, 2007 03:15 PM
gotcha, sunday afternoon alcohol post
V2K_CCTX
posted July 09, 2007 09:30 AM
Great info LeoVinceZX14.
My stand is on order and was wondering how to fit it with my Leo Vince System. Did you have to remove the lower rear fairing, looks like it?
Anyway...awesome looking bike. Pull the flies and remap. It was much easier that I expected. Guess all the hype about stripped and dropped screws...
Run the bike up to warm, like for an oil change.
Pull all the fairing crap off as desribed throughout the forum. Get a 8" #2 philips screwdriver. A high quality brand new one. Get a magnetizer and magetize it. Have a retreaval magnet handy too. Place the screw driver in position and using a rubber mallet, rap it three or four times firmly. Then slowly loosen the screw. Loosen all eight before removing, that way if you do run into trouble, you can simple tighten back down.. I used a 6" pair of needle nose to pull the plates out. Took longer to pull the fairings, tank, etc, then to do the job.
I used the Leo Vince 4-2 with PC3 mapped by motofuel, until I can get to a dyno, with flies out. Awesome!!!!!!!!!!!!!!!!!!
Keep us posted.
V2K_CCTX:
2007 ZX-14 Ebony Black (his) -- Leo Vince exhaust/flies out/PC3 mapped/SS brake and clutch lines/helibars/Competition Werkes GP pegs F&R/Puig Carbon Fiber Windscreen/Bikelites fender eliminator/custom CNC frame sliders & fork sliders
2007 CBR600RR Pearl White/Silver (hers)
2007 GV650 Avitar (hers)
2007 Vulcan 2000 LT (his) Muzzy Drag Pipes/Kuryakyn ProR Hypercharger/PC3 mapped/Chrome everywhere/everything
2007 Ninja 250R Silver (daughters) w/ Muzzy SS Exhaust
LeoVinceZX14
posted July 09, 2007 09:53 AM
Let me know if you want info on the chrome bracket......
V2K_CCTX:
You are correct. The lower belly pan is a goner. it takes up the space where the stand will come up. You will need the chrome bracket (picture #3) with its included rubber damper to limit the upper travel of your stand so it does not contact the chain....ouch. !!! Since we have the same exhaust no other clearance issues should arise.
Ride safe
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
V2K_CCTX
posted July 09, 2007 10:12 AM
LeoVinceZX14
Can you provide a phone # to call and order the bracket?
V2K_CCTX:
LeoVinceZX14
posted July 09, 2007 11:06 AM
V2K_CCTX check your PM.....
Dude:
You are all set. Check your PM and call my guy. I just spoke to him so he will be expecting to here from you. Let him know you are from ZX14.com.
Ride Safe.....
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
V2K_CCTX
posted July 10, 2007 06:41 AM
LeoVinceZX14
Thanks for the info...will call later today!
V2K_CCTX:
wildone
posted July 11, 2007 02:06 AM
HI ALL
got a new pair of Scorpion for my ZZR1400. I took out the db-killers before I
put then on the bike. I wonder what you all mean with "flies out"??? Is it just
that the db-killers are out of the muflers???
Next Q....anyone tried out with a T.R.E with gearindicator? it´s supposed to give
stronger midrange power.
Does this product need a PCIII and benchmapping to work ok??
Pros & Cons??
Estimated rwhp finally??
Tanx in advance
/Roger - Sweden
Scorpion carbon´s mounted...really nice
87gtNOS
posted July 11, 2007 04:06 AM
Roger, mine works pretty good with a map you can find on the PCIII website. It's the 'Muzzy slipons with NO flies' map.
I have that map with TRE006A(for flies out).
01 ZX12R
14black
posted July 11, 2007 06:08 AM
Guys:
How much were the grab handles on the sides? I assume you're in the States?
LeoVinceZX14
posted July 12, 2007 05:51 AM
Grab handles reply.....
14Black:
Yes I am in Florida. The grab handle on the left side visible in the photos is included with the Kawasaki centerstand part order. Note that you will have to remove the tail section to access the bolt holes the grab handle attaches to. Retail from a dealer is around $200 for the stand, grab handle and related hardware.
Ride safe....
'12 14R SE
PC V
Custom map
BMC filter
Sato frame sliders
Supersprox 42T
Cox radiator guard
Smiffy
posted July 12, 2007 09:40 PM
I've just received the SW Motech version of this stand through the post....over here, the Kawasaki stand was £168.00!!(That's approx $300.00) Who said we're not "tucked up" in the UK????
The SW Motech one comes without the grab handle but only costs £92.00 (about $175.00).
I have been told that the only messing around I will have to do with it is to cut the bracket from the original can and get it welded on to my Area P's to enable the rubber "stop" to be installed.
I'll let you know how I get on!!
Rob
V2K_CCTX
posted July 13, 2007 08:03 AM
Was going to install the center stand, but decided not to. Its for sale in the sale section. Didn't want to give up the ground clearance and it doesn't work with my aftermarket exhaust.
V2K_CCTX:
0.28286910057068 seconds processing time
