BIKELAND > FORUMS > ZX-14.com > Thread: ANYTHING TO REMOVE SPEED LIMITER? NEW TOPIC NEW POLL POST REPLY
bx-azzazin
posted July 01, 2007 09:12 PM
Hey guys I was wonder does any one have any info on whats out there for us to get rid of the speed limiter?
Any insight would be greatly appreciated...
BlackMagic14
posted July 01, 2007 09:38 PM
Speedohealer... That i believe is the only way
posted July 02, 2007 01:10 AM
or 18 tooth countershaft sproket, but speedo will be out alot.
ricksgsxr
posted July 02, 2007 02:50 AM
Turbo
blackbullet76
posted July 02, 2007 06:56 AM
Wont the TRE do it too?
kspz3
posted July 02, 2007 08:05 AM
Actually the stock set-up hads the speedometer off alot - 18 /40 gearing make it accurate.....
bx-azzazin
posted July 02, 2007 08:44 AM
Hey blackbullet76 the tre for the 14 doesn't remove it. Ivan states he'll be making something soon to remove it like the tre for the suzuki's
Hey black the speedohealer is it something you install, have you used it, or is it like a plug n play programming?
Kspz3 the 18/40 will you loose anything on the top end, and does that set up eliminate the limiter?
Thanx guys, talk to you soon.
bx-azzazin
posted July 02, 2007 08:55 AM
Hey black I just checked out the speedohealer on Brocks site. I gave them a call, they state i would remove the tre and replace with the healer. I'm going to do a little research and I'll let you know.
Halvefast
posted July 02, 2007 09:36 AM
Just grind off one corner on the sprocket nut, drops speedo by 25%
0.24693083763123 seconds processing time
