BIKELAND > FORUMS > ZX-14.com > Thread: MUZZY DRY SHOT,DYNOJET HUB,Q-Shifter & LCD. NEW TOPIC NEW POLL POST REPLY
zx1kr
posted June 20, 2007 04:43 PM
Got the Muzzy 50HP DryShot, DJ Quickshifter & the Hub w/ LCD display coming this week. Gotta step it up. I got Tru195 talkin' yap yap bout that 07 GSXR1k. He just did the spray & he's got 211 at the wheel. I knew he had to go that route though, with the way I was leavin' him on a roll-on. He had no choice. Wonder what he's gonna do now? He's not even gonna get a solid week of shit talkin and I'll be spoon feedin it right back to him! lol.....
I'll post the Dyno results, opinions on all the hardware and electronics.
Stay tuned!
1badzx12r
posted June 20, 2007 05:27 PM
yes do post.... really like to see a/f on spray....
zx1kr
posted June 20, 2007 05:34 PM        Edited By: zx1kr on 20 Jun 2007 18:35
Well, I will have tuned the A/F ratio to optimum. So, hopefully there wont be anything real scary to look at as far as that goes.
from9rto1k
posted June 20, 2007 07:28 PM
i was told by brock not to go over a 30 shot do to valves dropping..anyone?
zx1kr
posted June 20, 2007 07:33 PM
I'm pretty comfortable with the muzzy dryshot. Valves dropping? Elaborate.
smokinzx14
posted June 20, 2007 07:54 PM
TonyTooths bike on the dyno with a 40 shot made 207 hp and 177 on motor... that was with 6% added to the top of the p/c A/F was 13.0 12.9 .... Yours should make more with the Muzzy kit beacuse it shoots n20 right into the stacks .... Tony and my kit shoot into the ram air tubes before the filter ... Mine with a 30 shot made 214 , but that was not on a dyno ... I used the MPH and Weight at the track to get those numbers ... 505 pounds and a trap speed of 163 mph ..I'm sure ram air played a part in the numbers over Tonys numbers on the dyno..
I just installed a Muzzy kit on Jessejames bike and it a pretty slick set up (costly but slick) Hitting the spray in first gear is a NO NO even at 62 wheel base ...Smokin..
posted June 20, 2007 08:58 PM
Dood, your bike is makin me salivate... bst, muzzzy, galfer, hub etc....
:P
posted June 20, 2007 09:20 PM
Oh, BTW.
Yes Brock said he would never advocate the use of dry nitrous systems, as they are difficult to balance flow to all cylinders, and the harmonics can destroy cranks etc..
I have heard before of the valve train issue too.
I think if you aren't running awindow switch ppl are running it deep into redline, as the stock rev limiter is not agressive enough to prevent nitrous from overrevving, and the valve keepres are the weak link, as told to me by the guys at Carpenter, and orient.
The big bore big block engines with big cams anf ported heads are modifying the valve train as well. Larger keepers, etc
zx1kr
posted June 21, 2007 05:11 AM        Edited By: zx1kr on 21 Jun 2007 09:34
Well, I guess I'm gonna be playin' in the Motor soon!
What's the Big bore kit a 1427cc? Cams, Carillo rods , HD Springs ,valves etc. etc. Then I can throttle down the spray alittle. lol....
Anyone got any 1st hand experience with how this type of set-up runs? Streetable?
I had an 1164cc build on a 90' zx10 went thru 3 motors due to the waterjacket cracking. Sized down to 1109cc & it ran like an OEM motor. But, the power dropped big time.
Would like +200HP on motor, reliability is paramount.
1badzx12r
posted June 21, 2007 05:49 AM
just 6% added to map was enougth to get 13 a/f..... on a #34 jet.....i went with schnitz nitruos chart added 15% to 34 jet ....... i been looking real hard for a nitrous map to view...,.
zx1kr
posted June 22, 2007 03:36 PM
I installed the DJ Quick shifter today. Beautiful!!! This thing works like a dream! I've had it in a box for a while now, just never got around to installing it. Wish I had done it sooner! I'll get the 14 up on the Bike lift & take some pics w/ precise measurements for install. I've read there was a couple of issues installing them in the past. This one is Perfect!
As far as the NOS map goes, when I get the Muzzy kit installed & mapped out I'll gladly send anyone a copy. Though, I do not recommend using it on any system other than the Muzzy dryshot set-up for the 14. Also, even with that exact set-up in use I'd still adamantly recommend confirming AFR's on the spray w/ a dyno.
1badzx12r
posted June 22, 2007 04:26 PM
yes i would like a copy of that map....... i'm just use it as referance point.... or a wideband to check a/f with .......i believe nitrous is great stuff as long as ur careful other wise its a roll of the dice
1badzx12r
posted June 22, 2007 04:35 PM        Edited By: 1badzx12r on 22 Jun 2007 17:37
from these instructions its looks real easy to turn a dry to a wet system
http://www.coldfusionnitrous.com/WetKitatvinstall.aspx
would just have to build a manifold
Xtremespeed
posted June 22, 2007 04:46 PM
I've always wondered about the shifter. I don't shift with the clutch anyways. Will I benefit much from the quick shifter?
zx1kr
posted June 22, 2007 06:20 PM
This thing is SWEET! You'll drop a tenth or 2 with it. I thought to myself "Ah, how much quicker could it be?" Believe me it's quicker!
posted June 23, 2007 05:44 AM
yes considerably quicker , full throttle upshifts.
Bill, I'll drop ya a few bucks for the map! Free stuff is not good business practice!
Xtremespeed
posted June 23, 2007 11:46 AM
Cool. Lets see those pics.
trikchop
posted June 24, 2007 06:41 AM
i think using n2o with the quick shifter is a no no.
the pc quick shifter kills fuel to unload the motor to shift. but youll still have nitrous shooting in there. with nitrous its alot better to kill spark.
Xtremespeed
posted June 24, 2007 08:03 AM
Just use a window switch for the spray. That way you can have it shut off before you get to your shift point.
0.2643301486969 seconds processing time
