BIKELAND > FORUMS > ZX-14.com > Thread: Coolant capacity NEW TOPIC NEW POLL POST REPLY
fas550
posted June 19, 2007 02:41 PM
Coolant capacity
Sorry I don't have my owners manual handy; can someone look up the coolant capacity please?
Thanks OR better still how many bottles of Engine Ice do I need for complete replacement of the coolant with Engine Ice?
Frank
jarhead
posted June 19, 2007 03:16 PM
It will take 2 bottles of engine ice to get her full. I dropped the rad and then put everthing back together. I have just a tad bit left after filling everything including the overflow tank. I don't know how picky you are but there is also a bolt on the left side of the motor down low that can be pulled and you will get some coolant out of there also. Not a lot but some.
Hope this helps
hardcoremass
Powerhouse
posted June 19, 2007 04:23 PM        Edited By: hardcoremass on 19 Jun 2007 17:27
I have read posts suggesting that you use 50/50 of anti-freeze and engine ice. Is it safe to run 100 percent engine ice, its getting damn hot here...... The only other option I see is haul ass as much as possible which works for me!
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
Halvefast
posted June 19, 2007 05:12 PM
Takes 3.4L of coolant, and most aftermarket coolants like engine ice or liquid performance
is already mixed to a 50/50 ratio. I have wired my hazard switch to be a manual fan switch.
Works great in traffic and at the track.
V2K_CCTX
posted June 27, 2007 05:09 AM
Can you provide inst for the switch wiring?
Halvefast
posted June 27, 2007 12:06 PM
http://www.zx14.net/publicforum/index.php?topic=578.0
This is a "how to" that Wheelie put together.
0.22754192352295 seconds processing time
