tiger8u
posted June 16, 2007 12:23 AM
WHAT BRAKE PADS AND ROTORS are good for upgrade?
Okay,
I want to upgrade the brake pads and rotors on my ZX14? What is the recommendation?
I could only find EBC with pads and rotors. Any suggestions. Does anyone know if Brembo make brake set for this bike?
Sincerely
James
Honolulu, Hawaii
psycho1122
posted June 16, 2007 04:42 AM
"Brake Tech" Billet Iron Rotors and CP911 pads.
posted June 16, 2007 04:45 AM
replacing the brake lines with steel ones may be an obvious improvement. but the brakes on my ZX14 are one of the bikes better performaing components
ThrottleJunky
posted June 16, 2007 08:51 AM
I had a problem with the stock pads fading. Installed some EBC's with favorable results. I'm sure rotors and ss brake lines would be even better!
BobC
posted June 18, 2007 08:24 AM
If you're talking about braking performance, not looks, I've done many stops from around 200 mph and above on my 14 and I'd say the master cylinder, calipers and rotors are well up to the job, very good in fact. The only change I'd make is to fit some braided lines.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Old Guy
posted July 28, 2007 04:20 PM
I noticed my front fadding abit (rarely use the rear on track) towards the end of a session during my last track day. Was using it alot due to some ah...., interesting riders in our group and Portlands 2 straights that I hit 175+ on.
Hell my front rotors are blued!!
Going to try EBC's GFA race pads in front and HH in back. Plus fresh fluid.
Later comes the lines. Got good pressure and feel.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
posted July 28, 2007 04:24 PM
" The only change I'd make is to fit some braided lines. "
good starting point
countersteer
Didn't read the owners manual
posted July 28, 2007 10:17 PM
quote: "Brake Tech" Billet Iron Rotors and CP911 pads.
+1 braketech ductile irons are the way to go. just be careful when you wash your bike, the rotors oxidize (rust orange) almost instantly. forget about spray on chrome/wheel cleaner too :P
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
posted July 31, 2007 11:46 PM
Galfer has rotor kits now.10 mm oversized, lighter,
Tool man
posted August 01, 2007 04:50 AM
quote: If you're talking about braking performance, not looks, I've done many stops from around 200 mph and above on my 14 and I'd say the master cylinder, calipers and rotors are well up to the job, very good in fact. The only change I'd make is to fit some braided lines.
+++1
The banks are failing..
The banks are failing...
Invest in Ammo
