BIKELAND > FORUMS > ZX-14.com > Thread: 14 spitting fuel after 6 runs NEW TOPIC NEW POLL POST REPLY
lietoome
posted June 16, 2007 12:23 AM
Met up with my partner at the track. He ran about 6 times. His tailpipe and lower exhaust were smoking very lightly as we staged. During the run, he shut it down because it was acting funny.
His bike is pissing fuel down the exhaust and out the pipe.... My first thoughts are the PCIII. His first PC was junk. It dumped fuel straight into the bike regardless. His bike has been running really well. I plan on yanking the PC3 and starting their.
Any thoughts. I have more info, but I'm out for tonight.
hasta
Big_T_11
posted June 16, 2007 07:35 AM
Could it have bent a valve? You said acting funny? was it missing.
Tool man
posted June 16, 2007 07:50 AM
Stuck injector ?
The banks are failing..
The banks are failing...
Invest in Ammo
lietoome
posted June 16, 2007 01:17 PM
I have no clue. I'm a 'bolt on mechaniic'. I'm gonna pull the pc off and see how its running.
Would a bent valve make fuel leak from the exhaust? Last time it acted like this, the PC3 was bad. I replaced his PC with a new one and its been running fine since January. I hoping that the wheelie just broke the ground wire on the pc.
We parked it, fired up and it sounded like it was running on two cylinders. It continued to leak fuel & blow light puffs of white smoke..... If its not the PC, I will put it back to stock and have the dealer look at it.
I don't know how to mess with internals. Still keeping my fingers crossed that its the PC.
I'll let you guys know if its more than a PC.
posted June 17, 2007 07:15 AM
remove the pc and plug in stock config,
it should clear up
if ok then reprogram pc and retry, sometimes the programming gets corrupted
0.27063393592834 seconds processing time
