BIKELAND > FORUMS > ZX-14.com > Thread: 5.59 @ 130 1/8 mile pass NEW TOPIC NEW POLL POST REPLY
smokinzx14
posted June 06, 2007 07:54 PM        Edited By: smokinzx14 on 6 Jun 2007 21:10
This run was on a 30 dry shot ...I got on the spray real late in the run ...
smokinzx14
posted June 06, 2007 08:01 PM        Edited By: smokinzx14 on 6 Jun 2007 21:11
My 5.59 wheely pass ... I got on the spray to soon on this run and wheelied..
smokinzx14
posted June 06, 2007 08:07 PM        Edited By: smokinzx14 on 6 Jun 2007 21:13
Got my foot to close to the back of the pipe and burnt the shit out of my leg .. You can see when it happen because my legs flys way out to the right ...After this run my night got even worse .....
posted June 06, 2007 08:18 PM
Cool!
When did you lose the extensions and install the arm?
Nukedog
posted June 06, 2007 08:22 PM
What do you run off the spray?
8.77 in the 1/4 has to be 5.6x when you where NA...???
Nice numbers regardless...
02 Busa...Turbo...
09 YZF-R6S...
smokinzx14
posted June 06, 2007 08:34 PM
Cool!
Last week i posted picture of the new arm a few days ago ...Where you been >?? lol ...
gms118
posted June 06, 2007 08:42 PM
do you have you NOS on a button? Or throttle switch?
  Ignore this member    Click here to send gms118 an AIM message.
smokinzx14
posted June 06, 2007 08:44 PM        Edited By: smokinzx14 on 6 Jun 2007 22:31
On motor i have been 5.66 @ 125 and change at this 1/8 mile track ... At BMP i have run 5.63 @ 126 on motor ...I have no clue why BMP is faster , My guess would be BMP is a better track... On spray at BMP i went 5.53 @ 131 in the 1/8 and 8.56 @ 163 .....That was also a 30 shot.. But as you can see tonight 1/8 passes had problems ..One I wheelied and had to let off and the other i got the spray real late ... I think if i can ride it a little better it has some low 5.50s or maybe a very high 5.40s...After i burnt my leg tonight I was pretty much done for the night because of the pain... Smokin..
smokinzx14
posted June 06, 2007 08:47 PM
Throttle switch..Mico switch on the TB set at wide open throttle ..Smokin
smokinzx14
posted June 06, 2007 08:52 PM
I don't seem to pick up much ET on the spray in the 1/8 ( maybe a tenth at best) but it does pick up MPH pretty good 125 to 130 mph ..The spray seems to work better in the 1/4 mile ... Smokin...
Nukedog
posted June 06, 2007 09:27 PM
BMP is known for generous times - it is slightly down hill...
02 Busa...Turbo...
09 YZF-R6S...
smokinzx14
posted June 06, 2007 09:30 PM
That could be it .... I need all the help i can get ...lol..
Brent Davis
posted June 07, 2007 02:14 AM
Smokin' either mod your SMEG to lower it like I did or maybe use your sidewinder again I guess. As usual great times and sorry for the leg burn. Aloe is now your best home remedy friend.
SteddyTeddy
posted June 07, 2007 05:50 AM
Sorry about the quality of the vids. It's time to upgrade my camera.
smokinzx14
posted June 07, 2007 07:20 AM
The side winder is going back on soon ...Either that or wrap my leg with tin foil..........
ninja
posted June 07, 2007 08:48 AM        Edited By: ninja on 7 Jun 2007 09:48
Awsome riding!!
Get some real boots??
Nelson Taylor
posted June 07, 2007 09:21 AM
Nice runs Smokin'
Do you ever get you feet on the pegs?
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
smokinzx14
posted June 07, 2007 09:48 AM
Nice runs Smokin'
I can't ..My right leg is getting so bad i can only lift it up the use of my right hand ..
smokinzx14
posted June 07, 2007 09:50 AM
Awsome riding!!
I had real leather boots...I said had because they have a hole in them now ...lol
SteddyTeddy
posted June 07, 2007 09:51 AM
He used to be able to on the ZRX, but not the 14. You have to remember he ain't no spring chicken any more.LOL
smokinzx14
posted June 07, 2007 10:29 AM
J/K You know i love you sparky...
ninja
posted June 07, 2007 12:03 PM        Edited By: ninja on 7 Jun 2007 13:04
I can see your socks, get some MOTORCYCLE boots. much better protection IMHO. All those go fast parts must cost money. Saftey should be more important if your running 8 sec passes. Order some boots!
tonytooth
posted June 07, 2007 09:04 PM
Nice job Lee. Glad to see you sprayin the 30 with good results.
MySpace
  Ignore this member    Click here to visit tonytooth's homepage.
BlackMagic14
posted June 07, 2007 09:28 PM
Good Job Lee, Try ceramic coating your pipe mine is cool enough to touch for a second or so now still hot but not bad enough it would burn
smokinzx14
posted June 08, 2007 09:04 AM
It wasn't the pipe that burned me .... It was the exhaust that did the job , my foot ended up right behind the outlet .....I was on the spray and fire was pretty hot about that time ..
0.25504589080811 seconds processing time
