BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy airshifter install time? NEW TOPIC NEW POLL POST REPLY
lietoome
posted June 05, 2007 10:20 AM
Just curious what kinda time I'm looking at on the install. I'd like to get the airshifter and shift light installed in one shot. How long does it take for the actual install of the muzzy kit(not incliuding the removal of plastics)?
thanks
jeff
smokinzx14
posted June 05, 2007 11:22 AM        Edited By: smokinzx14 on 5 Jun 2007 13:31
Depends on you skill level .......My first one took a half a day ... 3rd one i installed took about 2 hours start to finish.. It's not hard work.......Smokin..
lietoome
posted June 05, 2007 07:58 PM        Edited By: lietoome on 5 Jun 2007 21:00
...just trying to figure out how much time is involved----might have to wait til next weekend. thanks, Lee.
Do I need to buy anything else to make the install easier? I really HAte running to autozone in the middle of an install.
thx
jeff
Brent Davis
posted June 06, 2007 02:43 AM
Make sure that you read the instructions well enough to get it right the first time as well. The pins from the harness that you have to take out and replace with the shifter harness can be tricky BUT all you have to do is verify the pins 2-3 times before you actually do the mod. Like Smokin' said, it'll be a more of a skill thing. I wanted all of everything that I could possibly hide to be hidden with the exception of the RAM which has to be connected to the shifter but then too I painted that black. Make sure that after you install the RAM tot he shifter and then to the new supplied frame bolt that the bike shift manually with your foot easily or else it will stick on you with just normal bike riding.
Good luck and just take your time.
smokinzx14
posted June 06, 2007 07:08 AM
thx
jeff
Only thing i had to get extra was some good wire ties ...Zip ties....
0.23550391197205 seconds processing time
