BIKELAND > FORUMS > ZX-14.com > Thread: Gearing NEW TOPIC NEW POLL POST REPLY
Pat Dietrich
posted May 30, 2007 05:27 PM
Gearing
Got to make this quick. My name is Pat Dietrich and I just became a trader. Let the Busa go and decided to go back to A Kaw and see what I can do with one of these. Got about 130 miles on it. Had it since this last Friday. Some of you may have seen my busa and know me from other sites. My Busa was a beautiful machine and when its all said and donem so will this bike. Not that it isn't real nice already, just needs some touch ups here and there. My question is on gearing. I want a vortex 43 rear but there is some sort of problem and won't be able to get one till the end of june believe it or not. But there are a few 42s available. Now i will be running a 190-50 shinko ultra soft on the rear. Would rather change the back rather than going a 16 up front. My question: ( finally, lol) What, at redline would 4th gear pull to with a 43 rear and a 42 rear? I want to be geared to run 153-154 at redline in 4th. So an exact number would be greatly appreciated.
By the way, nice to be on board!!
Bently
2012 14r In Blue and no Mods!
posted May 30, 2007 06:08 PM
Welcome aboard Pat you will love the bike. I'm not good with gear ratios so I won't attempt to anwer your ?. Can't wait to hear what you 1/4 mile times are, how soon before you go to the track?
Halvefast
posted May 31, 2007 12:58 AM
Here is what I can tell ya
17/43 gearing, I go thru the traps 4th gear shift light just coming on 50ft before =144mph
Shift light set @ 10600 (which is actually 10K) I'm 245lbs suited 1.50 60ft
Pipe no PC3 flies still in
Hope that helps?
BobC
posted May 31, 2007 03:45 AM
Pat,
When I calculate my ratios I take the engine rev limiter to be 10800rpm.
In 4th that would give 151mph with a 43 and 155mph with a 42 using a standard Bridgestone rear. I guess a Shinko would be about the same circumference.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
madcowzx14r
posted May 31, 2007 06:49 AM
WELCOME
WHATS UP PAT, IT'S ED, CAN'T WAIT TO SEE WHAT YOU DO WITH THAT NEW MONSTER. NOW DOWN TO BUSINESS, THE GENTLEMAN THAT POSTED 155 WITH THE BRIDGESTONE, WAS RIGHT BUT THE SHINKO IS A HEAVIER TIRE SO YOUR MPH WILL BE A LITTLE LOWER, BUT IT STILL SHOULD PUT YOU ABOUT WHERE YOU WANT WITH THE 42.
WELCOME TO THE .COM
AND FOR YOU THAT DON'T KNOW, PATS PROBABLY THE FASTEST GUY IN OUR TOWN, SO IF ANYONE WANTS TO STEP UP MY MONEY'S ON PAT.
IF YOU WERE FASTER MY ASS WOULDN'T BE IN YOUR FACE
1/4 MILE MILITIA
PhqOph Racing
smokinzx14
posted May 31, 2007 11:45 AM
Welcome Pat ... I use 16 /41 but i'm only 150 pounds ... My trap speeds range from 153 to as high as 158 but avg 155 MPH ... I tried a 43 rear and at 64 inches i could not keep the front end down ...I'm adding a longer swing arm and may have to try that 43 tooth again..
Don't worry most of us were Busa owners also ... Smokin...
Pat Dietrich
posted June 01, 2007 05:18 PM
I'm just guessing to have everything on after next weekend. The pipe could be the hold up. Give me a week to get used to it and put a few more miles on it and maybe towards the end of june I'll give it a shot.
Pat Dietrich
posted June 01, 2007 05:21 PM
Hope that helps?
So what you are saying is our tachs are 600 rpm off?? So , I'd have 800 rpm to go? Our redline is 10,800. For some reason i was thinking it was 11,000. Have to look at the tack again. Thanks for the reply!
Pat Dietrich
posted June 01, 2007 05:30 PM
WELCOME TO THE .COM
True on the heavier tire but a tire that hooks as oposed to a tire that won't will win every time!
Speaking of which, whats the stock tire like with a 4 over arm on a strip?? Thinking its coming right off and I'll just sell it for a good price and get a shinko.
Thanks for the compliment. But better hang on to your money till i prove myself on this one.
Pat Dietrich
posted June 01, 2007 05:32 PM
But i'm guessing you're shifting into 5th with that gearing? What are you running on the back, guessing an ultrasoft?
smokinzx14
posted June 01, 2007 06:57 PM        Edited By: smokinzx14 on 1 Jun 2007 20:02
Yup a Shinko 190 U soft ... Seems to work.... I ran the Battlax at stock wheel base and it worked great ( 9.18 @ 153 ) I tried it at 62 1/2 and it worked good also BUT we have a real good track that hooks ...I changed to the Shinko when i went to 64 inches.. I just made the bike 67 inches and i hope the Shinko still works because the MT shoot out tires are just to much money and wear to fast for me ..
Im in 5th at about 9k at the line , it think i may try a 43 on the rear and see if i can get closer to red line..... I shift mine at 11,300 right before the REV limiter at 11,400 and my Gauge seems to be right on the money in the upper gears ...In first and second it seems the Gauge is a little slow to keep up with what the engine is really doing ... I just think it doesn't have time to get caught up with this fast reving engine... But down track in 3,4,5 it does have the time and reads right on the money.. Shifting right before the 11,400 limiter is one of the biggest things you can do to go fast on this bike ....I should add that only works if you have a good pipe and map.. Stock there is no reason to go that high because the power is falling off fast after 9500.. Smokin...
Cajunboyz
posted June 02, 2007 03:34 AM
Pat, what color did you get???Like "Smokin" said there were plenty that were Busa owners,Hell I still own one,Have both.
Pat Dietrich
posted June 02, 2007 09:38 AM
So the redline is 11,400?? Better go look at my bike. If thats the case a 43 should be about perfect which by the way i got a call yesterday from Spencercycle and he found one for me. I know on the busa i could hit 161 before the limiter came on which was 11,400. Thats with 17-41 gearing.
Smokin' - didn't seem like you lost any mph then from going with the stock tire to the shinko. I used to run Pirelli tires and those were super lite. Liked them but not enough patch on the ground for not so good tracks.
Cajun- Got the black. Eventually it'll get painted Candy Brandywine. Trying to look at your seat but your picture is too small. Can you put up a bigger one or maybe you have one up. If so get me a link please. Just sent mine to Tobin ( Pa Freak) to get cut down. Hate sitting on top of bikes, like to feel like i'm in them!
smokinzx14
posted June 02, 2007 03:41 PM
Redline on the gauge is at 11,000 but the rev limiter kicks in at 11,400 .....
Cajunboyz
posted June 03, 2007 04:44 AM        Edited By: Cajunboyz on 3 Jun 2007 07:08
I never posted but a cuople of pictures,LONG time ago, I'll give it a shot
Halvefast
posted June 03, 2007 06:24 AM
Which would be 10,800 if it was off by 600rpm
http://secure.mycart.net/catalogs/catalog.asp?prodid=4929709
Check this out, Shnitz has a video that shows the tach off by 6%
kawabusakid
Fast as my $$ will take me
posted June 04, 2007 02:14 PM
wassup ...Pat?...I was riding the blue 14 @ martin on the track day.I was not running a shinko,instead i had a pilot power...i was hooking up good 180/55...glad to see ya crossed back...talk to ya later
  Ignore this member    Click here to visit KAWABUSAKID's homepage.
hubster999
posted June 08, 2007 11:10 AM
Wow Pat! I just ran across your thread and just wanted to say hi- Oh, and Pavel said to tell you hi also!
I just wanted to say it's about time you went back to a Kaw, and also wanted to tell everyone that Pat was and is still the fastest guy around our area! Talk at you later...
PS... Do you still have the '85 mustang? Is it for sale yet?
Hubble
Pat Dietrich
posted June 08, 2007 12:01 PM
Remember well! I kept stairing at the bike all day to make up my mind to see if thats what i really wanted, I did. lol
Pat Dietrich
posted June 08, 2007 12:05 PM
Hubble
Hubble??? As in Ben? Thanks for the props bud. I thought I'd keep my Busa forever, but it does seem when someone offers enough money, your not quite as attached as you once thought. HAHA.
SO what are you riding??
Mustang was sold to Charlie back in 97' . Have no idea where it went from there. Also something else i thought i'd keep. Loved that car.
BlackMagic14
posted June 08, 2007 12:45 PM
Just thought I would throw this in Welcome to the board and Brock posted a Gear ratio calculator thing not to long ago, STEVE use the search function and find that and post a link
Pat Dietrich
posted June 08, 2007 12:53 PM
Thank you! Why is it that when i use the search, it comes up with a whole lot of things not related to what i wanted searched out? For instance, Airshifter wiring. Nothing.
BlackMagic14
posted June 08, 2007 03:52 PM
That is actually a common misconception the search function only works for people who have 26000 post of silly and humurous pictures hence the only person that can successfully use the search function is STEVE LOL what is If I was at home on my computer I would send you that gear calculator but I am in Philadelphia for a few more days, Maybe Steve can find it Or actually Smokin may have it
posted June 08, 2007 09:05 PM
cajunboyz,
who did your seat?
Thats waht i'm after!
cajunboyz
posted June 09, 2007 04:33 AM
classicstitches@bellsouth.net located in Kenner Louisiana(southeast La.) Kisko SanchesPh.# 504-464-1055
0.225998878479 seconds processing time
