BIKELAND > FORUMS > ZX-14.com > Thread: PC3 (Map wont load) Help??? NEW TOPIC NEW POLL POST REPLY
Nelson Taylor
posted May 23, 2007 10:44 PM
Hey guys I just installed my PC3 went to load the stk exhaust, stk airfilter, secondary flies removed and the computer is telling there is an error sending the power commander the map. I even tried to reset the PC3, it wont even let me do that.
Everything else works.
Throttle Position %
Rpm
Identifies the serial #
Any idea's guys.
Anybody else had this problem.
I've sent Dynojet an email as well.
Thanks in advance
NT
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
Nelson Taylor
posted May 23, 2007 11:10 PM
Ok after unpluging it from the bike I connected the 9volt battery and its atleast showning me the already installed map.
Now the problem is the map is incompatable 263 !=199 version. This is the error message I am getting.
What this means I dont know. Any idea's
Best #'s
1.54
4.03
6.02 @ 121mph
dutchzx14
posted May 24, 2007 02:08 AM
U have to know that the pc3 will dry up the 9 volt battery in 15 minutes...
  Ignore this member    Click here to visit dutchzx14's homepage.
blackbullet76
posted May 24, 2007 06:06 AM
If the pc3 doesn't recognize the map, just rename it to something it will recognize. I had to do that to one of my maps. Also, make sure the max rpm of the map doesn't go past the redline of the 14. I don't think it will let it load if it's showing more rpm's.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
iflyems
posted May 24, 2007 08:23 AM
You have an old map that is incompatable with your PC. Open the PC software on your laptop for a new map. Then, open up another instance of the software with the map you have. Highlight all the map cells, click copy....then click on the blank map and click paste. This will convert the old map format to the new one.
Had the same problem with maps made for the PCIII for the ZX14...only problem was that I had a repinned 10R PCIII, so it wouldn't recognize the maps. Just copy and paste, then save...go to the bike and d/l the new save map, should work.
Nelson Taylor
posted May 24, 2007 01:04 PM
Thanks I'll try it again this weekend.
I think I have one of the repinned PC3 also.
Its a 244-410 instead of 244-411.
Best #'s
1.54
4.03
6.02 @ 121mph
posted May 24, 2007 05:36 PM
where did you pick that up
ZX-XIV
posted May 24, 2007 06:27 PM
Make sure that the cord is pluged in all the way.I have found that it plugs in then you need to push it a little harder to set it all the way in the power commander...
Nelson Taylor
posted May 25, 2007 07:29 AM
Another bikeland member
Best #'s
1.54
4.03
6.02 @ 121mph
raband
posted May 25, 2007 09:14 PM
Make sure the map isnt marked "read only'" or something stupid like that too
0.43339681625366 seconds processing time
