fastestbusaaround
I eat Fish...
posted May 12, 2007 01:55 PM
Edited By: fastestbusaaround on 12 May 2007 17:18
Throttle hesitation..
Lately, I'm seeing hesitation and delayed throttle response on my 14, as well as a lot of small popping on decel. I notice the hesitation mostly on the higher gears and the delay for WOT response is long; like seconds. Using Brocks no-files track map; tried a few different ones but always seeing the same results. It doesn't lack power, just that it's not there the instant I twist from 2nd up from any RPM from 3K up. It will eventually start pulling hard on WOT, but always seems to bog for a few secs 1st...especially noticeable from 2nd on.
With the gearing I'm using, this thing should just snap hard like a Banshee, like it used to...
I added a few ounces of diesel to clean the injectors today; no change though...
Any thoughts from the experts here? Plugs, PCIII ground, gas/air filter? I'm stumped. It used to snap hard before. Idle speed is about 900-1000 and if I go higher, it pops worse.
FYYFF!!!
Jim K
posted May 12, 2007 03:43 PM
Wires???
Never did get the whole "Harley" thing!
smokinzx14
posted May 12, 2007 04:39 PM
Set the throttle setting on the P/C 100% and 0% and relaod the Brocks map ... Brock said you should do this from time to time ..Kind of like a tune up ....He said in time maps can get out of wack and you need to reload them ....Smokin
never tried diesel but maybe some injector cleaner? maybe you got some crap gas
raptor14
posted May 12, 2007 05:08 PM
1. I used to run diesel through my car to clean it out. However, I've been using Techron lately. I run some through both bikes when I start riding again in the spring. Cleans things up good.
2. Check your plugs. R1 was doing the same thing last year. I pulled the plugs. They didn't look at that bad but I replaced them anyway. The difference was amazing, much more than I expected. Cleared up the hestitation.
posted May 12, 2007 05:10 PM
yup, plugs and air filter....
fastestbusaaround
I eat Fish...
posted May 12, 2007 05:36 PM
quote: Set the throttle setting on the P/C 100% and 0% and relaod the Brocks map ... Brock said you should do this from time to time ..Kind of like a tune up ....He said in time maps can get out of wack and you need to reload them ....Smokin
0% is easy...is there a way to set the 100% without running the engine or using a 9V battery? I don't have the adapter.
FYYFF!!!
smokinzx14
posted May 12, 2007 05:51 PM
I used the 9v battery .. i have no clue on how to do it anyother way ... Put a wanted add and see if anyone has a spare they can send you...I'm sure someone has owned more that one P/C........
1badzx12r
posted May 12, 2007 06:59 PM
quote: Lately, I'm seeing hesitation and delayed throttle response on my 14, as well as a lot of small popping on decel. I notice the hesitation mostly on the higher gears and the delay for WOT response is long; like seconds. Using Brocks no-files track map; tried a few different ones but always seeing the same results. It doesn't lack power, just that it's not there the instant I twist from 2nd up from any RPM from 3K up. It will eventually start pulling hard on WOT, but always seems to bog for a few secs 1st...especially noticeable from 2nd on.
from what i read here on your post
you need to call Ivan
smoothest throttle reponse on the market and don't forget the tre 006 for the pop... lmao
fracking FBA
fastestbusaaround
I eat Fish...
posted May 12, 2007 07:20 PM
Blow me 1bad --
FYYFF!!!
1badzx12r
posted May 12, 2007 07:25 PM
have you made THE CALL yet
posted May 12, 2007 08:04 PM
you got to be kiddin.....troll
fastestbusaaround
I eat Fish...
posted May 12, 2007 08:39 PM
He's fuckin with you man....he knows how I feel 'bout him...:d
FYYFF!!!
3boysand3bikes
posted May 12, 2007 09:05 PM
quote: you got to be kiddin.....troll
Yes.... he is kidding... he is a sponsor on here and was giving maps away when the flies first started coming out... (cyclepaintmetal.com) He is making fun at the lengthy arguments that we had in which FBA was not afraid to speak his mind.. ha ha Anyway.. he is a good dude!!!
By the way... BILL... how is your friend doing.. theone that posted some bizarre speed posts on here??!! PS Nice to hear from you!!!
1badzx12r
posted May 13, 2007 05:17 AM
Got the wrong dude.... but hey i like the post.... FBA I hear you gotta spend 200.00 to get the PACKAGE .... THIS the best thread you ever started FBA my ribs are killing me
posted May 13, 2007 06:21 AM
sucked me right in damn
