BIKELAND > FORUMS > ZX-14.com > Thread: High Motor Temps. NEW TOPIC NEW POLL POST REPLY
fury
posted May 08, 2007 02:50 AM
High Motor Temps.
I did a search for high temps and missed the posting (idf there was 1.)
Anyways what have you guy's been doing to combat the engine temps?
Suggestions please.
Currently 20-40 degrees F.
Thanks for your time.
posted May 08, 2007 02:15 PM
Hi, this is just a suggestion - search under keywords "engine ice" in ZX14. There was a lot of overheating posts with that and other products mentioned within the thread. Good luck.
No need for reposts, there's a plethora of info.
posted May 08, 2007 06:43 PM
install pipe and pc and it will run cooler, it also runs cooler when broken in
how many miles you got?
fury
posted May 09, 2007 11:52 AM
under 1000 km.
I have the pc. (have not installed it.)
I was hoping to stay stock on the pipe.
raptor14
posted May 09, 2007 03:23 PM
1. Ride fast!
2. Ride on a cold day!
3. Get rid of the stock exhaust with the catalytic converters (which hold heat in) and get a PC which eliminates the lean running condition.
4. I've been running Engine Ice this summer and honestly, I can't tell any difference between it and regular 50/50 Ethylene Glycol and water, other than price. Some swear by it but back-to-back experience on my 14 says it isn't worth the price.
5. Add about 1/2 bottle of Water Wetter to either the regular antifreeze mix or to the Engine Ice. It won't make any difference for steady state operation at slow speed but it will allow the engine to heat up slower at stop lights and cool down quicker when you get going.
6. What seems to be the best solution is to ceramic coat the headers, inside and outside. Refer to http://www.bikeland.org/board/viewthread.php?FID=27&TID=31248&set_time= for further discussion. Brock says it works and that's good enough for me.
Xtremespeed
posted May 09, 2007 04:03 PM
The less ethylene glycol you can run the better. For every 1% ethylene glycol, you raise cylinder head temperature approximately 1 degree. You also need to be aware that the display is an indicator and not an actual gauge. Just because you have several bars showing doesn't mean the engine is too hot. These beasts make a ton of power, and heat is a natural byproduct.
Flame On
Fuel Air & Spark
posted May 09, 2007 04:40 PM
Full synthetic oil
fury
posted May 10, 2007 02:26 AM
Gentlemen thank you for your responses.
Advice taken.
0.2114999294281 seconds processing time
