paulers
posted May 07, 2007 10:18 AM
Newbie seeks suggestions.
Hello all,
I am a new rider and just drove off the lot with a new ZX-14. I'm a large guy about 6'4" and 320 lbs and I was wondering if someone can give me tips on how to configure my bike to accomidate my height and weight.. I already know that I need a new spring so I have ordered one from Race-Tech and plan to have the dealer install it but what else can I do? I feel like my bike groans everytime I get on
All help is greatly appreciated.
raptor14
posted May 07, 2007 12:29 PM
For comfort, get the Heli Bar risers. I'm only 6' and they improved my comfort quite a bit. Much less pressure on the wrist.
paulers
posted May 07, 2007 12:31 PM
Thanks for the sugestion, I will check it out. The lady at Race-Tech also mentioned valveing the front and back but Im not sure what she is talking about.
Tool man
posted May 07, 2007 01:48 PM
If you already have the 1.2 kg Race tech springs installed, you are one step in the right direction. The stock valving should be ok for you. You will need to dail up your compression and rebound to suit you needs. I am 6'5" 320 and have 12,000 mi on my 06. I am looking at an Ohlins rear shock but so far $$$ has made me not buy one.
The banks are failing..
The banks are failing...
Invest in Ammo
paulers
posted May 07, 2007 02:19 PM
thanks Tool Man,
I just ordered the parts from Race Tech today,
I ordered the 1.2 Spring (SRSPS5818116) and some fork shocks to support my weight (FRSPS3825120). Oh and I also picked up some Heli Bar risers as recommended by Raptor14. What are the good points to installing a Ohlins rear shock? Which one are you looking at?
Tool man
posted May 07, 2007 04:36 PM
Ohlins offers a KA544 shock for the 14, spring rated to your request. $$1174.00
I was talking to the Ohlins race tech at Fontana, he almost had me convinced.
Sometime soon
Invest in Ammo
phytrax
posted May 07, 2007 08:15 PM
I recommend the Heli risers too. Good luck with those. Corbin seat is nice too, once you break it in. It won't make the bike fit you any better though.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
dalan
posted May 08, 2007 05:49 AM
Um... a NEW RIDER with a ZX-14 for a first bike? Am I reading this right?
paulers
posted May 10, 2007 08:10 AM
This is actually my second bike but it's been a while since I rode daily. Is it hard to replace the rear spring or should I have a professional do it? I was hoping to find some replacement instruction online but have not been able to find any. Does anyone have any good links that may help me with this?
Thanks.
posted May 10, 2007 08:42 AM
Edited By: dubious on 10 May 2007 09:43
quote: Ohlins offers a KA544 shock for the 14, spring rated to your request. $$1174.00
Sometime soon
The ohlins can be had with remote preload adjuster, which can come in handy if you 2 up ride, helps maintain geometry when passenger climbs on, just tighten it up!
The ohlins is infinatley superior, adjustment ranges for dampening much broader, and more sensitive!
GHOSTMAN
posted May 10, 2007 09:05 AM
My next step is to go ohlins shock and spring.
(6'2", 390lbs)
Still doesn't do too bad with stock cranked up, but still getting the ohlins setup.
I'm There Whether You See Me Or Not.
paulers
posted May 10, 2007 09:08 AM
Is there a special tool needed to make those adjustments to the stock spring?
princesskiwi
MISTRESS of SMACK
posted May 10, 2007 09:44 AM
paulers - hey congrats on the bike!
Just watch your temp being that you are in Arizona.
There are posts on the site about it - so check those out.
I really like the 14 and if you keep the secondary butterfly valves in - I think it is a great choice for a newer rider of your height and weight.
Let's face it - you can't ride a 600.
I found the 14 to be easy to handle at slow speeds.
I rode it around LA, lane splitting through traffic.
I also thought the power delivery was quite smooth when I needed to pass.
The only part of the ride that was uncomfortable was the pinch I got in my back and wrist from barely using ANY throttle and having to keep my throttle arm Super Still.
Muzzy makes a frame slider that can help with any tip overs...you are a big guy - but the 14 I was riding tipped over and I couldn't hold it up once it started going.
Corbin makes some sweet bags for the 14.
paulers
posted May 10, 2007 09:52 AM
princesskiwi,
Thank you very much for your reply! I really appreciate the wonderful info. I knoticed today on the way to work (7:30am) that all the bars in my temp gauge were full. I had called my Kawa dealer before about it and he said that they run hot during the breakin phase. Is this true? should I have it checked out by another dealer? I will be sure to check out the other posts. I'm also getting about 35/mph, is that normal for a ZX14? I'm guessing it has a lot to do with my weight.
Thanks again!
posted May 11, 2007 11:44 AM
pk who's bike did you drop?
