BIKELAND > FORUMS > ZX-14.com > Thread: front sprocket washer NEW TOPIC NEW POLL POST REPLY
creepdog
posted May 04, 2007 09:10 AM
im this topic is in here some where but im having trouble finding it.new to this.how do you go about flattening out the washer?thanks for any help.
full trc pc k&n filter pulled flies stacks ign. advancer custom mapped
lietoome
posted May 04, 2007 09:23 AM
I use a hard rubber mallet and a big flat tip screwdriver to flatten it out. I also have a 1/4" round punch that I use. I've even used the head of a 1/2" bolt. You just have to flatten the lip of the washer to remove the sprocket nut.
BobC
posted May 05, 2007 01:12 PM
Gently: with a very small drift or cold chisel and a "not too big" hammer. Remember it's the gearbox output shaft with oil seals and associated bearings on it.
chez
posted May 06, 2007 04:33 PM
I flattened the used one with a wooden mallet and traced around the shape of it onto a sheet of thin stainless plate. Cut out the shape and filed it and filed it and hey presto, new washer....
Chez
  Ignore this member    Click here to send Chez an AIM message.
creepdog
posted May 07, 2007 05:48 PM
thanks for the suggestions.gonna try it again this week.
0.22855591773987 seconds processing time
