BIKELAND > FORUMS > ZX-14.com > Thread: Speed O Healin' NEW TOPIC NEW POLL POST REPLY
Ninja_Knight
posted May 03, 2007 12:15 PM
Speed O Healin'
I have used the search feature and looked up the various posts on Speedohealers and I got a lot of great info, but most of the posts discussed using the Speedohealer if you are changing your gearing. I simply plan to get a Smeg and PCIII but have no intention on changing the gearing. Do you guys still think I should get a Speedohealer and what would the benefits be? Thanks in advance!
fastestbusaaround
I eat Fish...
posted May 03, 2007 12:34 PM
Speedo's off by at least 8.5% (over) with stock gears/sprockets...
FYYFF!!!
Xtremespeed
posted May 03, 2007 06:36 PM
Fix the speedo and you slow the odometer. Also, cases the gear indicator to read improperly.
The Blue MUle
posted May 03, 2007 06:39 PM
the only down side I have found is that the gear in dicator will go to 6th but then indicates 5th?? It has something to do with the voltage signal??
fastestbusaaround
I eat Fish...
posted May 03, 2007 06:42 PM
Only if you're running very low gearing...like I am...stock gears shouldn't be a problem.
FYYFF!!!
Ninja_Knight
posted May 03, 2007 09:07 PM
Okay, so ya think I should still get it even if I do not change my gearing? The Brock's Smeg package comes with a Speedo with the exhaust and the PCIII and I thought I would just get that if you guys think it would be helpful.
flyboy
posted May 03, 2007 09:24 PM
The device is nice so you can have an accurate speedometer... as for travelling amongst the Highway Patrol. It is also nice if you should decide to change gearing at some later point and again, want an accurate speedometer. Lastly it is one of the devices used to fool the electronics to go pass the restrictor above 186 mph or thereabout.
If you have access to a GPS, calibrate your most important speeds, ie. 25, 55, 65, 70 and mark them on your plastic speedometer overlay with a different permanent color dot representing a different speed. This saves you money and doesn't affect your power if the above three factors are not important to you.
"The World's Fastest Indian"
One fast red ZX-14,
Ninja_Knight
posted May 04, 2007 08:26 AM
Thanks flyboy, I think I may just do that instead of the Speedo... I am putting enough stuff on this bike as is for right now. I won't have any room to sit.
Jim C
posted May 04, 2007 09:09 AM
Ninja,
I just got the same setup from Brocks. Easy to install and like flyboy said it is best to have a GPS to calibrate. I ran mine at 100mph there was a 6 mph difference did the calculation on the speedohealer web site and I was done. Took it out on another test drive and my speedo was right on with the GPS at different speeds.
Jim
  Ignore this member    Click here to send Jim C an AIM message.
ninja14
posted May 04, 2007 10:28 AM
Save your $ and leave it alone..............it is giving you a "safety margin" from speeding b/c you will be going slower than indicated at all times.......while clocking accurate mileage.
Ninja_Knight
posted May 04, 2007 10:32 AM
Oh. Okay, well, since I am just now getting out from under the oppressive thumb of past speeding tickets then perhaps I should just skip this then. Does anyone know on average how much digression the stock speedometer has? I know I read it somewhere already but I am tired of the search feature.
posted May 04, 2007 11:27 AM
about 6%
Good luck keping it within the speed limit though ....LOL
its like good (bad) drug, just can't get enough, everytime ya ride it you want your fix!
Ninja_Knight
posted May 04, 2007 11:32 AM
That's what they make track days for, right? Yeah right! Escort radar detector here I come!
posted May 05, 2007 07:18 AM
speedo error saves my ass, thanks kawasaki
get a healer if you want to go faster than 186 simple as that
BIKELAND > FORUMS > ZX-14.com > Thread: Speed O Healin\' NEW TOPIC NEW POLL POST REPLY
0.3180730342865 seconds processing time
