BIKELAND > FORUMS > ZX-14.com > Thread: dyna shift light NEW TOPIC NEW POLL POST REPLY
jdrill04
posted April 30, 2007 06:28 PM
dyna shift light
does anyone have a dyna shift light, and minder installed on there 14? because i ordered one and would like a little help installing it. pictures would be greatly appreciated.
thanks
smokinzx14
posted April 30, 2007 06:46 PM
I can get some pictures for you in a day or so... Hang tight ... smokin...
jdrill04
posted May 01, 2007 04:58 AM
thanks alot smokin
SteddyTeddy
posted May 01, 2007 05:42 AM
They are very simple to install. Probably the best hookup on the 14 is to find the Tach wire and hook to that. I have one on my ZRX and love it.
smokinzx14
posted May 01, 2007 04:48 PM
jdrill04
posted May 01, 2007 05:23 PM
smokin did you ever get the shift light to work, and if you did how did you hook it up. to the coils or to the tach. thanks for the pictures.
jdrill04
posted May 01, 2007 05:25 PM
i also have the muzzy air shifter and would like to hook it up direct if it is pretty simple, but i have to quick shift to keep the bike down sometimes, most of the time. it would be great as long as i can still beable to shift with the button when i need to.
smokinzx14
posted May 01, 2007 05:36 PM
Seems to work great , i will be testing it weds night ... RED wire to switched power ... BLACK to ground ... the other two wires pulg into the shift light pig tale... GREEN wire of the shift minder to the white wire with red tracer on the first coil in the left side of the bike ... I used this to hook to the coil wire >>http://secure.mycart.net/catalogs/catalog.asp?prodid=4930249&showprevnext=1 ..It's like 15 bucks but you don't have to cut into your factory coil wires...Smokin...
smokinzx14
posted May 01, 2007 05:39 PM
I didn't hook it up as an auto shift ( yet ) someone told me on another board that if you spin it will keeps shifting and could mess up your trans ...I think i will just keep mine as a shift light for now .... Smokin...
SteddyTeddy
posted May 01, 2007 06:45 PM
Never thought of that with hooking up as an autoshift. Point that thing so it points right at you face. I get so focussed on riding that if it wasn't pointed at me I think I would miss it.
smokinzx14
posted May 01, 2007 06:50 PM
Teddy when i'm tucked in it's right at my eyeball....
jdrill04
posted May 02, 2007 05:21 AM
smokin i tried to find the adaptor you bought for 15 bucks, but it wont come up. could you give me the name of the piece or the manufacturer. i even copyied and pasted the site you wrote.
lietoome
posted May 02, 2007 05:47 AM        Edited By: lietoome on 2 May 2007 06:49
try this...I'll be adding this bad boy to the cart when I get my shifter on FRIDAY!!!!!!!!!!!!!!!
smokinzx14
posted May 02, 2007 08:17 AM
Thanks ... thats what i'm using ...Smokin...
jdrill04
posted May 02, 2007 02:11 PM
thanks guys
jdrill04
posted May 02, 2007 06:37 PM
i am tyring to hook it up to the tach , but i seen on one thread were they said if you splice into the tach signal wire you will mess it up. because the 14 runs on a can system. is this true. if not i need to know witch wire is signal wire from tach witch one is power wire.
ryan schnitz
posted May 03, 2007 05:20 AM
You can't get a tach signal from the Instrument Cluster. You have to either tap into a coil ground wire, or use the tach adapter found at the above link.
iflyems
posted May 03, 2007 06:43 AM
Bullshit.....I had an autometer pro-shift on my old GSXR for years. Yea, it would spin, and yea, it would shift if it went past the shift point, but at that point the run is toast anyways, so I would just shut off. I rebuilt the motor twice, and the tranny was always fine.
I would prefer to have an autoshift on the turbo, too many things to watch. It might happen. But you know, according to the NHRA and prostar rules, autoshifters on bikes are illegal. Guess I'll have to have an rpm activated "boost controller"
0.40956997871399 seconds processing time
