BIKELAND > FORUMS > ZX-14.com > Thread: quarter mile rear sproket NEW TOPIC NEW POLL POST REPLY
jjc1800
posted April 29, 2007 11:10 PM
need rear sproket for quarter mile what size should i get, not changing the front. thanks fellas in advance
BobC
posted April 29, 2007 11:59 PM
To get the same final drive ratio as the 16/41 which a lot of people use for quarters you'll need a 43 or 44 tooth chainwheel. That will most likely require a longer chain too, it's starting to get expensive now so it might be worth reconsidering changing that gearbox sprocket after all.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
jjc1800
posted April 30, 2007 03:14 AM
what do you guys think about a 16/43 ratio because i already have a 43 tooth sproket on the rear and i want just a little more.
fastestbusaaround
I eat Fish...
posted April 30, 2007 04:32 AM
I have that setup, though I don't race the 14 -- and it's insane. Only issue now, is keeping the front end down...top speed is limited now to 167, which is fine for me anyway, but this thing runs through the gears faster than you can possibly imagine.
FYYFF!!!
jjc1800
posted April 30, 2007 09:27 AM
keeping the front wheel down wont be a problem because im lowered and stretched about 6 inches
ninjaboy311
posted April 30, 2007 10:39 AM
Think again, I'm slammed and 11" over with 16-43 gearing, and can still lift the front on occasion.
6" over will lift easily.
SteddyTeddy
posted April 30, 2007 12:56 PM
Have you run the bike on the 1/4 mile yet? Do you have any drag racing experience? If not, run the bike as is for a while until you get some seat time.
smokinzx14
posted May 02, 2007 09:02 PM
That's the truth !!! I just tried 16/42 no way could i keep the front end down tonight ....16/41 works better for me ...
zxbob
posted May 03, 2007 03:23 AM
With or with out the juice !
Bob
smokinzx14
posted May 03, 2007 08:04 AM
Bob
Without !!!
0.27378988265991 seconds processing time
