BIKELAND > FORUMS > ZX-14.com > Thread: Dyna shift minder and muzzy air shifter ?? NEW TOPIC NEW POLL POST REPLY
smokinzx14
posted April 30, 2007 06:28 PM
As most of you guys and gals know i have a Muzzy c02 air shifter and i just picked up a Dyna shift minder with shift light from one of the zx14 members.... The shift minder has a 12 volt RPM output that can be used to trigger the air shifter ..The Muzzy air shifter has a digakill box that kills the fuel as well as adj kill time and delay time....My question is what wire would i use from the Digakill to make it an auto shift .....Anyone done this set up before?? Can it be done with a diga kill box ? Thanks Smokin..
lietoome
posted April 30, 2007 06:49 PM
I'll have the identical setup, please keep us posted.
smokinzx14
posted April 30, 2007 06:53 PM
I will if i can get it working without burning up all my parts ...lol...
zx12mark
posted April 30, 2007 08:19 PM
use the wire that flashes the shiftlite to trigger the wire going out of the push button that activates the shifter.
you might have to invert a positive pulse to negitive or vise versa.use an relay.
what ever rpm the shiftlite flashes it will auto shift
posted May 01, 2007 06:40 AM        Edited By: dubious on 1 May 2007 07:41
If all else fails...
Hook it to the power wire on your shift light, when light goes on, bike should shift!
burnout
posted May 01, 2007 07:33 AM
I agree. Your going to have to fire both the solenoid and the DigiKill, which one of the wires on the long Muzzys harness already does when the horn button is pressed. If you can isolate the wire that becomes hot when the horn button is pressed, you should be able to fire that with the shift light lead.
1/8 5.66@129.77
1/4 8.74@159.60
zxbob
posted May 03, 2007 03:39 AM
Hmmm ..... no reply from Lee ..... he's work'in on it
Bob
burnout
posted May 03, 2007 04:31 AM
I read in another of his posts that he became concerned that if he spun the tach relay may cause him to bang through the gears all at once and mess up his tranny. I've been thinking about it, however, and Muzzy puts in protection for "button bounce", which should prevent this.
Adams Performance goes about it a little differently. I think they have an autoshift unit that has a time delay in addition to the RPM window.
I'm wondering if the PCIII hub relay might be the way to go. Couldn't you use gear position and RPM in order to limit relay firing more than once per gear.
1/8 5.66@129.77
1/4 8.74@159.60
smokinzx14
posted May 03, 2007 08:17 AM
Well i'm going to set back and watch someone else be the tester for this one ... For now i'm just going to use it as a shift light ...
CajunBoyz
posted March 27, 2012 04:32 PM
Smokin, did you ever use this dyna shift minder as a shift light???
CajunBoyz
posted March 28, 2012 03:48 AM
Bump for Smokin ??
I saw in another thread you had just tied into the #1 coil & I bleieve it worked??? I know CRS is a mother, but see if you remeber any of this.. Thanks
AcadianaZX
Advertiser
posted March 28, 2012 05:10 AM
Hey Lee, I'm using the Schnitz TPRS to trigger my Digi kill.
With relay. 85 +12, 86 grd, 30 grd, 87 -12 to Digi kill green, 87a nothing.
James
AcadianaZX
Advertiser
posted March 28, 2012 05:42 PM
Lee, you can call me if I need to explain better. With the relay I'm grounding the green wire at the left handle bar. If the shift minder is putting out 12v it should work fine. I previously tried to trigger it at the horn switch with no results. 337-654-1663
James
posted March 28, 2012 05:47 PM
James
wow this is so old i have no clue what anyone is talking about ..
posted March 28, 2012 05:51 PM
Man this is old stuff all the way back to my 06 zx14 ... I never did get the shift light to work as an auto shift , not sure i ever even tried to hook it up that way .. The shift light never did help me because i never could see it no matter where i put it ..
What i'm ising now is MPS auto shift box set at 11k ... It works great and no need for a shift light that i can't see anyway .. hope that helps ...
AcadianaZX
Advertiser
posted March 28, 2012 05:52 PM
Got me good. Now that u mention it, I see it was way back.
0.24850296974182 seconds processing time
