BIKELAND > FORUMS > ZX-14.com > Thread: new camera mount NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted April 24, 2007 11:09 AM
new camera mount
I made a new camera mount. It's mounted to where the grab handles are located on the european models. I've got a problem though. Under hard accelleration, my digital camera cuts off. It was cutting off from just reving the engine, but I put some rubber mounts on it and that helped some. The vibrations are cutting it off I guess. I hope to perfect it some more so I can get some better videos. Anyways, here's a still shot from the video I did today.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
blackbullet76
posted April 26, 2007 11:06 AM
Well, I'm just about fed up with trying to make this mount work without cutting my camera off. Does anyone know of a mount I can get that bolts up like this? If not, then maybe some material that will kill the vibration? If I can't find one, I guess I'll have to fab up something different, but I really like this view. Will be cool to make a video at full throttle.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
posted April 26, 2007 12:02 PM
You may find the solution in a camera less sensitive to vibration.
blackbullet76
posted April 27, 2007 03:54 AM
Yeah, I've been needing to upgrade for a while. I might go that rought.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
posted April 27, 2007 07:50 PM        Edited By: stevewfl on 27 Apr 2007 20:52
i've not shopped for cameras but surely you should be able to get some vibration specs on each model
xtro
posted April 28, 2007 02:41 PM
Look at the GPS mounts from Ram-mount ...
I have several standard things I can mount to my upper area .. remove a bolt for the clip-ons .. replace with a few mm longer .. and with a small ball mounted there .. you have the entire line to choose from and many lengths of conections ..
I can place my digital camera, both still and movie, above, below, to the side of the screen.
Also I use this for my GPS when just roaming around ..
as for vibration .. my camera had to be using memory rather than the DVD recording .. nothing I could do there ..
the 33x zoom and 16x9 DVD Samsung I got is cheap .. cheap in reviews too .. but cheap .. small .. and a totally kick arse zoom .. seems ok for just going on the bars ..
blackbullet76
posted April 28, 2007 04:13 PM
My camera is old. It's a Sony Cybershot DSC P-52. I've got a 1gb memory stick in it that will do 45 minutes of video. I've had it a long time. I messed with the mount some more, but with no luck. I figured I'd upgrade, so I ordered a nice camcorder yesterday. It's a Sony Handycam DCR-SR80. I think it will do the trick. Plus the quality will be a whole lot better.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
blackbullet76
posted May 01, 2007 07:37 AM        Edited By: blackbullet76 on 1 May 2007 08:38
Well, I got the new camcorder in yesterday. I tried it out wallago and hell, it's more sensative than my old camera! I think if I had a full exhaust with just the one pipe, it wouldn't cause problems. Oh well
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.26440215110779 seconds processing time
