BIKELAND > FORUMS > ZX-14.com > Thread: Clutch problems-- part ll NEW TOPIC NEW POLL POST REPLY
flyboy
posted April 17, 2007 12:39 PM
In an earlier post I reported on early morning startups that I would release the clutch in first gear and the bike would bearly move even with the clutch fully out. After riding for five minutes the clutch would be back to normal. Most recommended warming it up longer before starting out. What was always the case was the gear only seemed to engage when the clutch lever was 3/4 of the way out. When new I remember the clutch catching much sooner when beginng the hand release.
Sunday, after a long warm up, I got on the bike and the clutch lever would not move at all. Even with two hands it would bearly move. Bike would show 1st gear on the display but the bike would not move as the gear was not engaged. I undid the rubber gomlet covering the hydralic fluid "overflow?" and immediately lost all pressure to the clutch lever which is strange since I didn't undo the nut.. The lever would now just go back and forth using two fingers. I obtained a can of Motul and started to place a small amount into the resevior as I would work the clutch lever and then bleed the top "overflow/" and the bottom one near the foot peg. After I believe I eliminated all air bubbles I once again had pressure on my clutch lever but the bike would not go into gear.
I do not drag race. Just accelarate hard and go fast. The bike is still under warranty. The local dealer says he can't take me for two weeks. It's very frustating. Could salt from Bonneville gotten into the clutch plates or some other location? Has anyone else had this problem? Any recommendations beside a good bottle of Merlot? Thanks--
"The World's Fastest Indian"
One fast red ZX-14,
flatoutbu
posted April 17, 2007 01:47 PM
Just throwing ideals out....think maybe one of the steels was sticking from being warped and was stuck. After you tried to pull in the clutch it put pressure against the plate and it finally broke loose?...just a thought..
06 Blue 14
9.008 at 153mph @ 195 suited
iflyems
posted April 17, 2007 02:16 PM
+1
smokinzx14
posted April 17, 2007 03:28 PM        Edited By: smokinzx14 on 17 Apr 2007 16:29
I guess salt could have gotten in the cover that holds the piston that pushes the clutch rod... It's wide open in there and if salt got in there from the front sprocket spinning that could bind the piston ... pull the cover off and take a look , it only a few bolts...Salt does bad things in a real hurry ....
shane661
posted April 17, 2007 04:33 PM        Edited By: shane661 on 17 Apr 2007 17:34
A service manual would serve you well. I would clean and lubricate all joints, and bleed the system. The manual also covers clutch inspection procedures.
smokinzx14
posted April 19, 2007 08:37 PM
Well ???????????????????????????????????????????????????????? what did you find out ????
posted April 20, 2007 06:04 AM
I would pull the slave cover, and the clutch cover and inspect the entire unit.
Maybe you have a clutch basket problem. I've seen baskets grooved so bad the plates could not seperate, cause they were binding on the basket.
flyboy
posted April 20, 2007 06:37 AM
Thanks guys. The local Kawa shop took the bike in yesterday. I'll keep you informed. Having a manual is an excellent idea
One fast red ZX-14,
flyboy
posted April 24, 2007 10:05 AM
Just got word-
Disintegrated slave driver from the salts of Bonneville.
One fast red ZX-14,
posted April 24, 2007 10:28 AM
and you never lost fluid?
weird...
smokinzx14
posted April 24, 2007 10:44 AM
Just got word-
Mark one down for old Smokin .....
Tool man
posted April 24, 2007 12:33 PM
Sure throw a little salt in the wound, Smokin
The banks are failing..
The banks are failing...
Invest in Ammo
flyboy
posted April 24, 2007 01:20 PM
I will have to find that opening so I can tape it up--
One fast red ZX-14,
posted April 24, 2007 03:24 PM
duct tape to the rescue
0.25801610946655 seconds processing time
