Speed
posted March 29, 2007 01:32 AM
Edited By: Speed on 29 Mar 2007 02:44
GPS mounting
Hi!
I have a Garmin Quest and want to mount it on my ZZR1400/ZX-14. Does anyone know if this will suit? http://www.techmounts.com/products/index.php?page_function=detail&product_id=1
In other words, whats the diameter on the "stemopening"? Thanx!
posted March 29, 2007 04:29 AM
Welcome aboard...
Just drop Techmounts an email and tell them you need a GPS mount for a ZX-14 . They'll take care of you. Make sure to mention you're a member of this website.
Speed
posted March 29, 2007 04:46 AM
Ahhh...thank you! :]
Speed
posted March 29, 2007 05:00 AM
It will suit, case closed.
Jim K
posted March 30, 2007 04:58 PM
Edited By: Jim K on 30 Mar 2007 18:04
Here's my setup. A Mio C310X gps and a Techmount. Works GREAT!!! And not a Thousand dollars!
Just go here,
Punch in the info and the site will tell you what to order.
Never did get the whole "Harley" thing!
Bud0212
posted March 30, 2007 05:17 PM
I'm using a Techmount....great unit!
zerMATT
posted March 30, 2007 08:38 PM
zumo 550, $714 from Amazon... comes with a mount and hardwire power wire for the bike. That makes the gps cost only about $600 if you look at it that way.
Not to mention being the best, motorcycle friendly, waterproof, gps made so far.
My wife even thinks it's cool in the car, and she's not into gadgets.
posted March 30, 2007 09:08 PM
Matt you were going to post pics? I have the RAM mount on the left side, bottom bolt of Ram only and have it leaned towards the inside. Is that something like you're doing?
Jim K, I'm seriously open to the tech mount product, but let me ask you something, how hard is it to get the GPS off that mount? Or are you pulling that whole shaft out of the neck? If so, does it then remain bolted to the tech mount? Why I ask is I use this thing as much in the car or more than the bike and I like the Garmin factory parts for serious ease of changeout. Matter of fact, the RAM that comes with Garmin stays bolted to the bike, GPS just pops off. Although I like your position of the GPS a little better on the bike.
Dayum I babbled on, anyway thanks for any help folks
tslewisz
posted March 31, 2007 06:55 AM
Big fan of Ram mounts, here. To use on a ZX-14, just get a RAM .87 X 2.25 W/ 11 MM HOLE & 1" BALL, a longer machine screw for the "clipon" bracket and a spacer.
http://65.102.174.116/rammount/productdetail.aspx?partnumber=RAM-B-252U
Exact same setup I used on my '04 RT.
posted March 31, 2007 07:00 AM
no offence tsl (in advance) , but IMHO the ram mounts aren't even in the same league ... side by side test it's pretty obvious.. Ram stuff is okay as a "beginner" mount (for lack of a better term) but the build quality just isn't there and there are way way way too many reports of them failing... with the $$$ value of the gear I've got bolted to the bike I simply can't afford to roll the dice on a ram mount.
tslewisz
posted March 31, 2007 07:10 AM
No offence taken, fish, but since my Ram stuff worked fine on my dual-sport bike ridden off road and thousands of miles on my RT, I think it will be fine on the 14.
posted March 31, 2007 07:17 AM
that's cool,
fastestbusaaround
I eat Fish...
posted March 31, 2007 07:26 AM
For those of you who use the stem-mount Techmount...question...does it stay rigidly mounted in the stem, or does it spin easily from side to side? I mounted my RAM in the center stem and once all tightened up. it's rock solid, still, I'd prefer the Techmount because it gets the GPS lower down closer to the stem and has a much cleaner look. I'll post pics of my ZUMO on the 14 later today. Stevewfl, the Zumo should be stem mounted for best use and look...need to add a $5.00 part to do that, but it's easy.
FYYFF!!!
posted March 31, 2007 07:32 AM
The techmount doesn't budge an inch... I have 4 of them... used them on several different bikes.. machining is unbelievably precise.. .totally overengineered for the application.. the Ram mount isn't in the same league (just hold the two side by each and it's immediately obvious) ... and no... it doesnt spin or move or shake.. it's bombproof.
fastestbusaaround
I eat Fish...
posted March 31, 2007 08:55 AM
Interesting...I was cruising their site earlier...and have a couple a questions fer ya on that mount. Will send ya a PM. Agreed on the RAM mount VS the Techmount, but that's also greatly reflected in the price.
FYYFF!!!
posted March 31, 2007 09:55 AM
if you guys could post pics that would be fantastic. FBA can you get me a description of the 5 buck part too
thanks !!!!!!!!!!
posted March 31, 2007 09:56 AM
Fish whats the security about with tech mount can anyone just pull it out of the stem? if so and you remove it, does the Zumo just pop off or is it the 4 bolts? I swap between vehicles (actually its in the car more)
Ninja_Knight
posted March 31, 2007 10:11 AM
quote: Fish whats the security about with tech mount can anyone just pull it out of the stem? if so and you remove it, does the Zumo just pop off or is it the 4 bolts? I swap between vehicles (actually its in the car more)
+1
fastestbusaaround
I eat Fish...
posted March 31, 2007 04:30 PM
quote: if you guys could post pics that would be fantastic. FBA can you get me a description of the 5 buck part too
thanks !!!!!!!!!!
Just headin' out to party with some babes Steve, but I'll answer all of your questions later and you only have to unclip the Zumo out of the bracket to move it to the car kit...
FYYFF!!!
posted March 31, 2007 04:40 PM
thanks !!!!!!!!!!
Hey please post pics of the babes AND the zumo ~
we're going riding tonight and its one of those nights we'll be riding with babes that have their own bikes
Eric with the silver 'busa is joining me too and hopefully we'll all run into Tonytooth and Bigdtd and H2to???? from ZX12.com
posted March 31, 2007 06:06 PM
Steve.. it doesnt just "pop out" of the stem... it's in there pretty tightly... tight enough that there's little or no difference between taking the techmount off the bike or any other piece of kit off your bike... say I want to steal your mirror... that's not hard, is it?
Anyways.. the techmount has a standard AMPS hole pattern in it, and the Garmin mounting base screws right to it... very straight forward and easy install... FYI their factory is near where you live.. .why not drop by and get a tour?
zerMATT
posted March 31, 2007 08:21 PM
Sorry about the delay on pics Steve. I just took some - I'll start a new thread with them shortly.
posted March 31, 2007 10:20 PM
quote: Steve.. it doesnt just "pop out" of the stem... it's in there pretty tightly... tight enough that there's little or no difference between taking the techmount off the bike or any other piece of kit off your bike... say I want to steal your mirror... that's not hard, is it?
Thanks, may take that tour! I noticed they're in winter park...an hour or so away.
One more question, the amps thing on the tech mount means I have to unscrew 4 bolts to move the GPS to the car if I understand the mount? Our is the AMPs mount you're referring to have the little ball looking thing?
Thanks again in advance.
Jim K
posted April 01, 2007 12:35 PM
The GPS unit easily snaps on to the Techmount, like this...
The plate with the 4 fingers is an accessory Techmount sells...
The Gps cradle snaps on to the plate...
The Gps snaps to the cradle...
The finished piece. It slides into the hole in the steering stem. It's very "snug" and doesn't move at all.
posted April 01, 2007 12:55 PM
amps is the 4 hole screw pattern... its an industry std mounting pattern
