chris3232
posted March 20, 2007 10:56 AM
Removing the TRE
I am removing my TRE and putting it back to the standard stock configuration so I can regain my shift indicator. I have removed the secondaries. My question is: I don't remember wich wire goes where when I remove it from the TRE and go to insert it back into the factory wire clip. I believe they call it the green gps connector. Does anyone know which wire goes where?
ninja14
posted March 20, 2007 11:14 AM
The wires are the same on either side of the plug...just match up the G/R to G/R, LG to LG and BK/Y to BK....the other wire is for the oil light.(G to Y/G)
posted March 20, 2007 11:16 AM
mix and match? like a rainbow?
ninja14
posted March 20, 2007 11:21 AM
I don't remember which socket each goes in, but it won't matter......long as the colors all get along :-)
GUNNER
posted March 20, 2007 11:34 AM
Removing the TRE will result in Ivan placing a Spell on you to go slow!! Ivan isn't a force to be messed with
chris3232
posted March 20, 2007 03:34 PM
Thanks, that worked out good.
fastestbusaaround
I eat Fish...
posted March 20, 2007 03:54 PM
Ya, and don't ferget to burn the TRE...
FYYFF!!!
1badzx12r
posted March 20, 2007 04:07 PM
quote: Ya, and don't ferget to burn the TRE...
and don't piss on the fire to put it out
fastestbusaaround
I eat Fish...
posted March 20, 2007 04:23 PM
'zactly!
FYYFF!!!
chris3232
posted March 20, 2007 04:48 PM
Man, the power difference is very noticeable now since I removed the TRE and took out the flies, plus I have my gear indicator back. This is freakin awesome!
dbeadling
posted March 20, 2007 05:06 PM
ivan spell must be working
Black14
posted March 20, 2007 06:58 PM
quote: Man, the power difference is very noticeable now since I removed the TRE and took out the flies, plus I have my gear indicator back. This is freakin awesome!
Do you have a pcIII?
chris3232
posted March 21, 2007 06:17 AM
Yeah, I have the PCIII, Brock's smeg and now no flies
GUNNER
posted March 21, 2007 07:06 AM
quote: ivan spell must be working
Ivan's MoJo must be failing him in his old decreped age!
