BIKELAND > FORUMS > ZX-14.com > Thread: Air Compressor install started for air shifter...... NEW TOPIC NEW POLL POST REPLY
brent davis
posted March 17, 2007 05:42 PM
I bought the air compressor from Wal-Mart for $10 and took it completely apart from the case and mounted it under the seat like a few guys here that have shown me how they did theirs. I bolted the pump to the bike with bolts and the actual psi gauge that came with the pump kit is retained and can be seen by simply bending down to see how much pressure is in the tank for the shifter. So far, so good as far as testing the pump goes. I even reused the pump switch as well.
Black '06 ZX-14
icetee
posted March 19, 2007 04:47 AM
looks like it will work well for you...what shifter did you use for your bike? Can you show pic's of it?
THE VIEW FROM THE REAR NEVER CHANGES,UNLESS YOUR IN THE FRONT!
tonytooth
posted March 19, 2007 04:56 AM
Very nice and clean. It looks like a $200 part. Thumbs up!
MySpace
  Ignore this member    Click here to visit tonytooth's homepage.
Brent Davis
posted March 19, 2007 07:27 AM
Sure and thanks. Nelson Taylor sent me a pic of how he had his compressor installed and it was in the same area, so I copied him.
I will take some more pics today as I have to take the bike damn near apart to install this stuff right. The psi gauge that you see is mounted upside down so that when I need to check to see if I need more psi, I just look under the tail section and turn the switch on which is also mounted just above the compressor. Basically everything will be hidden and neat.
BTW, if any of you are reading this and have used a compressor for airing your tank up, what is the max psi to use. I tested this pump and man that thing pumped all the way to 250 psi before I cut it off. It was going to keep going too. I'll take more pics and post here for anyone else that may wanna do something like this one day.
icetee
posted March 19, 2007 09:37 AM
thanks for the info..I've been wanting to install one my only problem is that I'm a neat freak. it has to be discrete looking..... will be waiting for the updated photos.....
kawasaki_rick
posted March 19, 2007 01:31 PM
I like 150-180 psi.
smokinzx14
posted March 19, 2007 01:40 PM
I run mine at 125 psi . No problems and never once missed a shift..
brent davis
posted March 19, 2007 05:27 PM        Edited By: brent davis on 19 Mar 2007 18:28
Great news then. The pump makes 125+ psi like it aint nothing so I'm good there.
Oh well, had to take the damn thing apart to install the Digi-Kill and wiring for the airshifter but I think it'll be worth it. I like the idea of the horn/shifter switch so that you can use either or. I painted the shifter RAM cylinder to match the bike too and give that stealth look plus the bottle is hidden. I have a new screen coming too so that is why the shield is off.
Black '06 ZX-14
Nelson Taylor
posted March 19, 2007 07:33 PM
Looks good Brent.
I havent tried the system I have on the 14 yet but I usually keep the psi at about 120-125lbs.
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
smokinzx14
posted March 19, 2007 07:52 PM
Brent i used the same air pump from walmart on my zrx1200 ... It works great but i did have a problem with the hose that it came with the pump ... The line is just not made to hold 125 psi for any time ... I had mine split twice before i replaced it with braided line ... I'm just given you a heads up before you head to the track... Better to upgrade in now while everything is still apart... Smokin..
Brent Davis
posted March 20, 2007 03:09 AM
Thanks Nelson. I will get it to the 125 setting and keep it there.
Thanks smokin' for the tip on that. I do have plenty of extra -4 braided line as well to compliment that. Why didn't you go with an on-board compressor on the 14 this time?
smokinzx14
posted March 20, 2007 08:37 AM
CO2 and 800 to 900 shifts without thinking about airing it up before i make a pass...For me thats priceless ...lol....
Brent Davis
posted March 20, 2007 09:46 AM
MUTHA fug. Man I really like that avatar. Too bad the pipe isn't a real SMEG.
icetee
posted March 21, 2007 05:45 AM
Brent i like what youv'e done, I think that's the way I will go also, the black blends in with the frame real well to....some of the air shifter linkages are too big
Brent Davis
posted March 21, 2007 06:35 AM
icetee, the Muzzy kit was definately worth the price since it is as complete as can be and also uses the stock frame bolt to mount the top of the shifter cyliner RAM. Others require you to drill holes into your frame and all that. I fired the bike up last night and just gotta put the fairings and stuff back on, fill the bottle with compressor air and test it out. The Digi-Kill was a little tedious to do since you gotta take pins out from the PC III and splice all that stuff but wasn't bad at all doing so. I will add that once you connect the shifter cylinder to the shift fork and connect it all to the bike frame, tighten it all down and see if you can make manual shifts and see if the shifter goes freely without binding. Mine was binding and I had to slightly bend the shifter fork just a tad in a vise to get it to shift smoothly with the cylinder hooked up and tightened up fully.
0.22942900657654 seconds processing time
