BIKELAND > FORUMS > ZX-14.com > Thread: new clutches slipping???? NEW TOPIC NEW POLL POST REPLY
HOTROD360
posted March 05, 2007 07:15 AM
ok im no expert but i have done this many times i changed my clutches rode the bike all was fine then out of no where clutches start slipping?????
what you fellas think it is??? im going to open up and make sure all is fine. but want any suggestion some may have.
posted March 05, 2007 07:40 AM
I hope this does not sound bad, but... did you check the adjustment on the clutch...
HOTROD360
posted March 05, 2007 08:51 AM
ITS HYDRAULIC IT SHOULDNT NEED ADJUSTMENT, RIGHT??? IM NEW TO THE HYDRAULIC CLUTCH THING
bishopzx12
posted March 05, 2007 09:21 AM
same happen to me the first time i changed mine. mined slipped in the upper rpm. i tooke everything back out and made sure all the steels were facing the same way i also had made sure that i had soaked the clutches before hand in oil. i dont know if this willhelp but a few of my steels were tuned opposite the other and that fixed my problem. i am not sure if it will help you but i hope it does
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
posted March 05, 2007 09:41 AM
I could be wrong, but isnt there an adjuster down in the clutch cover?
bishopzx12
posted March 05, 2007 10:21 AM
Mike you are right but there is no adjusting needed big guy. Like hot rod say the clucth on the 14 does not need adjusting. Are you still playing with that zx12 clutch. I am i changed the clutches in my 12 last week its twice as bad as the 14 the 14 chnage is so smoothed
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
HOTROD360
posted March 05, 2007 10:43 AM
as soon as i get home im going to take everything out and put everything back in 1 by 1 again....
sometimes the easiest things give u the most darn problems....
michaelball31
posted March 05, 2007 03:42 PM
same thing happened to me, took all clutches out, and resoaked them in oil for 1/2 hour and has worked fine since.
HotRod360
posted March 05, 2007 06:09 PM
well looks like i had 2 steel in the wrond way than the others, turned them around re did everything and no problem oh well easy fix.... thanx
bishopzx12
posted March 06, 2007 07:32 AM
Hot rod this is what thi sboard is all about. I am glad i was able to help
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
0.35824704170227 seconds processing time
