BIKELAND > FORUMS > ZX-14.com > Thread: ZX 14 restriction NEW TOPIC NEW POLL POST REPLY
fast_dude007
posted February 18, 2007 07:35 PM
ZX 14 restriction
I just bought a 2007 ZX14 and was reading some articles that the zx14 is restricted to 290 km/h / 180 miles per hou. If so, does anyone know how to remove the restriction?
Thank you for any feedback.
hawkman
posted February 18, 2007 08:53 PM
Don't know how to remove it, but know how to get around it. ----> Speedo Healer
posted February 18, 2007 09:02 PM
Its fairly common knowldge that its 300 KM/186 MPH. And thats on most sportbikes, not just the ZX14.
BobC
posted February 19, 2007 12:11 AM
A Speedo Healer is quite popular.
http://www.speedohealer.com/eng/intro.htm
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Hannula
posted February 19, 2007 12:51 AM
Gipro and G-pack:
http://www.bikehps.com/acatalog/GIpro.html
http://www.pr-powercontrol.fi/shop/product_details.php?p=2393
phytrax
posted February 19, 2007 04:14 AM
You can gear up to get around it also. Went up one tooth on the front sprocket, which is about 6% gearing. Speedo is almost dead on now and it raised the limiter to about 197, which is more than I can do with my bags. If you dropped a tooth in the rear, the speedo would be even closer and would push the limiter to about 202.
KX450F - kickstand
>>> MySpace --CLICK-- <<<
thevak
posted February 20, 2007 03:19 PM
I was given this by someone on the board not sure if it works as I have not tried it. But anyway here it is.
Hey ,the unit i have is an adaption of a bypass that was made by hardcore cycle out of germany it whas originally made to bypass rev limiters on 325I BMW,s and they reworked the wiring harness to plug into the 14 it,s called a {lie box}i guess because it lies to the crank censor. if you can,t find it through hardcore i can dig up my shipping slip and adress and send it to you.
  Ignore this member    Click here to visit thevak's homepage.
mano 2
posted February 20, 2007 07:46 PM
+1 tooth on the front sprocket or -2 teeth on the rear sprocket will also do it. It will also make speedo accurate.
mano 2
posted February 20, 2007 07:50 PM
The limiter will come in at about 195mph w/gear change. Sorry.
phytrax
posted February 21, 2007 10:50 AM
From what I've seen, this would make the speedo read 3% low for most people. Stock the speedo normally reads 8% high. +1 front and -1 rear would put it at 0.5% high if I'm doing the math right. Either -1 or -2 in the rear will be geared too high for most people though, unless you're running top speed with some extra engine mods.
KX450F - kickstand
0.25482511520386 seconds processing time
