1badzx12r
posted January 29, 2007 06:43 PM
Muzzy no flie's map
Got it installed.. I think it needs more work .. Stumbles at take off from idle in 1st .. boggy in mid-range cleans up at high rpms.. I KNOW ITS JUST A BASE MAP ... feedback is all i'm posting
BlackMagic14
posted January 29, 2007 07:01 PM
Have you contacted Muzzy's about the problem??? I am sure he would tweak the map
1badzx12r
posted January 29, 2007 07:08 PM
quote: Have you contacted Muzzy's about the problem??? I am sure he would tweak the map
Easier to post and let Rob find it and gather more info from others that used it to respond on there 2 cents worth ... Than use muzzy's channels
BlackMagic14
posted January 29, 2007 10:00 PM
There is always the other solution sell the Muzzy buy a Brock and get a Spot on map
posted January 29, 2007 11:01 PM
quote: There is always the other solution sell the Muzzy buy a Brock and get a Spot on map
oh YES
+1
ZXGRIFF
posted January 30, 2007 04:41 AM
1bad, maybee its just an extreme altitude difference?
1badzx12r
posted January 30, 2007 07:37 AM
quote: 1bad, maybee its just an extreme altitude difference?
i believe you is correct.. Spock would say logical to buy Brock... But Kirk always gets the green babe's with 3 boobs
posted January 30, 2007 03:43 PM
And the green 3 boob babes are drag queens.
road rage
posted January 30, 2007 07:35 PM
Edited By: road rage on 30 Jan 2007 19:43
I think you may have the same map I'm using, labeled muzzynoflys. I got it from one of the guys here; blackbullet76. This map's set up for the following;
MUZZY FULL EXHAUST,NO FLIES,SCREEN REMOVED FROM BACK OF AIR FILTER, MUZZY BLOCK OFF PLATES, 13.0 A/F RATIO, SEA LEVEL.
My bike doesn't have the exact same mods as above, my mods are:
TWO BROS SLIP-ON, NO FLIES, W/ PC3, 3300 FT ABOVE SEA LEVEL.
Running the above map in my bike; I thought the fuel was a bit high and slightly rich(standing at the rear of the exhaust, the gases would burn my eyes within 3 seconds of exposure). I'm at a greater altitude and don't have a full exhaust system so less fuel is required. though it sounded bad-assed when I ran it up to 10K rpms, really mean indeed.
If you're bogging down it's mostly likely running rich a bit. I decided to modify the file with another (stock w/no flys) to find a happy meadian between the two. If a particular reading was +10 on the stock w/no flys and on the muzzy file the same reading was +22 for example at the same location, I simply added the figures together and devided them by 2, giving me +16 as the new setting for that location (this should add just a bit more fuel since I'm moded just a bit more over stock w/no flys + slip-ons) . You can create these files within the program by using the 'map compare' feature. Once you load the 2 files, find the average table, copy and paste into a file and then save under a new title. I'll keep the muzzy file for spirited riding, and use the one I created for day to day use. If you want the file to try for yourself, just let me know and I'll send via e-mail.
Phil
3Boysand3Bikes
posted January 30, 2007 09:52 PM
Actually Road Rage.. I believe that he is talking about the map that was just released by MUZZYS over the past week or so. I live in Wisconsin so I have not even loaded it yet. I am hoping some of you guys get enough feedback to Rob that they get it tweaked. Also Road Rage, I believe this map being talked about is for Full System (MUZZYS), with Flies removed and no other mods at all.
1badzx12r
posted January 31, 2007 09:09 AM
quote: Actually Road Rage.. I believe that he is talking about the map that was just released by MUZZYS over the past week or so. I live in Wisconsin so I have not even loaded it yet. I am hoping some of you guys get enough feedback to Rob that they get it tweaked. Also Road Rage, I believe this map being talked about is for Full System (MUZZYS), with Flies removed and no other mods at all.
exactly the map i'm talking about... straight from muzzy
