BIKELAND > FORUMS > ZX-14.com > Thread: need assistance NEW TOPIC NEW POLL POST REPLY
justoyz2
Justoyz Racing
posted January 26, 2007 03:47 PM
need assistance
bought a wrecked zx14. The bike won't start, it will turn over, but the fuel pump will not work. There is an error message 46 showing, however when I changed it with another it works on the other bike, but not on the mine. This is what I have checked so far:
DOWN DEVICE/FUEL PUMP RELAY: (swapped with the one on my zx10, the 10 started with this device)
FUEL PUMP: by passed and tested the pump (working)
GROUNDS: checked all known grounds
the FI error is 46 (fuel pump relay)
I have found only 3 relays, 1 for the head lights (working)
1 for the flashers (working) and 1 for the fuel pump itself (working) Action: interchanged all relays with each other and tested the resistance (all working properly)
Is there any other devices that will keep the fuel pump/injection system from working?
does anyone have the full copy of the manual (pdf) I only have the first 316 pages.
LandspeedLarry
posted January 26, 2007 06:19 PM
Owner's manual states that the ignition has to be recycled after tip over. Try on-off-on with the key and disconnect-reconnect battery.
Home of the World's Fastest Naturally Aspirated motorcycles.
ninja14
posted January 26, 2007 06:36 PM        Edited By: ninja14 on 26 Jan 2007 18:40
When I went down I turned it off and started right back up.
Just because the pump is turning does not mean it is pushing fuel - check for flow.
justoyz2
Justoyz Racing
posted January 26, 2007 06:41 PM
the pump is not pumping, however I know it works. straight wired the pump to ensure the unit is working.
justoyz2
Justoyz Racing
posted January 26, 2007 06:42 PM
tried the battery disconnect and changed batteries as well.
ninja14
posted January 26, 2007 07:33 PM
Pump not pumping, but works.....
Pull the fuel line......bottom of tank..........see if gas comes out when the pump motor turns.........no smoking when you try it :-)
posted January 26, 2007 08:49 PM
If its dark in your garage, don't use a bic lighter to see....
justoyz2
Justoyz Racing
posted January 27, 2007 06:56 AM
Ninja 14,
I tested the pump with 12 volts. You will hear the pump when powered
posted January 27, 2007 08:36 AM
Are you just trolling for a free soft-copy of a manual? I have to believe that you realize that hearing a pump try to work and it actually pumping are two different topics entirely.
Trolling is uber-ghey
justoyz2
Justoyz Racing
posted January 27, 2007 06:22 PM
okay, First Thanks to all that tried to assist with the delima!!!!!
I isolated the problem to the ECU, Thanks to zrx1220r solved the problem.
it was the ECU that caused the ignition/fuel problem.
So, anyone with an ECU, that works please give me a call
808-542-2496
Thanks again
posted January 27, 2007 06:37 PM
Just so you guys will know > justoyz2 was not trolling ....He came over to my house tonight and we tested his ECU on my bike and the fuel pump would not come on ...Now he needs a ECU ..If anyone has one for sale please PM justoyz2...Thanks Smokin....
ninja14
posted January 27, 2007 11:04 PM
Think they are like $900 new.....
blackbullet76
posted January 28, 2007 09:07 AM
$900? ouch!
nightmare
ACP Racing
posted January 29, 2007 04:36 PM
$900? ouch!
+1
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
ninja14
posted January 29, 2007 05:27 PM
Hey - the cans are about $800 each ......the ECU is a bargain :-)
0.42405796051025 seconds processing time
