BIKELAND > FORUMS > ZX-14.com > Thread: hieght with swingarm extensions? NEW TOPIC NEW POLL POST REPLY
blue max
posted January 24, 2007 10:54 AM
alot of the bikes i see look like they are jacked in the air. do they have to sit that high or will they bottom out under the fender when lauched? my bike is slammed right now with stock wheel base. i have made my own links
best 9.23
ZXLNT
posted January 25, 2007 04:27 AM
Well that depends, the extra leverage the extensions put on the shock will make the suspension softer..
blue max
posted January 25, 2007 05:51 AM
interesting, how is the rideability? i am not a twisty guy just a cruiser
best 9.23
flatoutbu
posted January 25, 2007 10:23 AM
There is almost nothing you can't do with a stretched bike. It wont lay over in a corner as good as stock wheelbase...but i dont do corners
06 Blue 14
9.008 at 153mph @ 195 suited
blue max
posted January 25, 2007 10:32 AM
my bike is as low as i can get it without rubbing when launched, will i have to raise it ?
best 9.23
ZXLNT
posted January 25, 2007 11:26 AM
It depends on how stiff your suspension, how much you weigh, how low it is, how bumpy the roads are... But yeah more than likely..
BlackMagic14
posted January 25, 2007 02:27 PM
So you should raise the rear to stock height when you stretch your bike? I am 300 pounds and have ordered a stiffer SPRING from Trac Dynamics
flatoutbu
posted January 26, 2007 08:31 AM
I also have a stiffer spring on my bike i got from trac. Depending on what lowering links you have, i used to have mine on the lowest hole in the muzzy 3 hole links. It rubbed a bad hole into my undertail. With the new spring and aftermarket swingarm, i have to put it in the middle hole because the 3rd was waaay to low. The mounting point for my aftermarket swingarm must be alittle higher than the stock one, which causes the bike to be lower. If i can get away with it i might run the lowest hole in the links come race season if i can adjust the spring to keep it from bottoming out, I'm 235 suited.
06 Blue 14
BlackMagic14
posted January 26, 2007 02:30 PM
So I should be ok in the second hole with the stiffer spring?
jeepersracing
posted January 26, 2007 03:08 PM
i have a cbr 900 rr with a 300 rear tire and 18inch over swingarm!!!!!if you can ride than a swingarm want make it any different just in a parking lot . what makes it loose handling is lower to ground not it being longer
  Ignore this member    Click here to visit jeepersracing's homepage.
Stalwart
posted January 26, 2007 04:52 PM
Send that guy to basic english classes
Stuart
Ridin' the Trump train.
BlackMagic14
posted January 26, 2007 08:09 PM
I am not talking about handling I am talking about it rubbing the rear undertail section when I launch the bike
jeepersracing
posted January 26, 2007 09:14 PM
so sorry that i can' t type so smart people like most of you here can understand it. is that goooooooddddd enough engliskgjhnq3rsdvj;n for you
short swingarms have a time with undertails it's really hard to stop rubbing from suspension sqwat most take out the undertail
flatoutbu
posted January 27, 2007 08:11 AM
Are you going to use your stock swingarm or are you going to a aftermarket? My guess (depending on how stiff your spring is) you should be fine on the second hole with a stock swingarm. The spring is really just used to set ride hight, if your still having problems with bottoming out you need to have the shock revalved. You can crank the spring up alittle to raise the bike and that might get you some clearance between the tire and undertail on a hard launch. With the stock set-up i had my spring cranked as hard as it would go to keep it from rubbing....which it did anyways. Experament, find what works best for you.
06 Blue 14
BlackMagic14
posted January 27, 2007 10:50 AM
I will be installing bolt on swingarm extensions going to 63 in
0.45853900909424 seconds processing time
