BIKELAND > FORUMS > ZX-14.com > Thread: lowering straps NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted January 20, 2007 10:14 AM
lowering straps
The local dragstrip will be starting test & tune next month. I was wanting to lower the bike just for the track and I figured straps would be best best for that. Couple questions, how much will this help on keeping the front wheel down, and are straps available for the rear or will I have to get the dogbones?
BlackMagic14
posted January 20, 2007 10:37 AM
For the rear you could technically put straps on it I have never seen it done but it wouldnt be a good idea!! the straps would eliminate SQUAT which is very important straps on the front end help ALOT I would also recommend sliding the front forks down about an inch you can buy a set of adjustable dogbones for around 70 bucks then you can rais eit back up pretty easily after you race... you could try patricksperformance.com for the dogbones
lietoome
posted January 20, 2007 10:48 AM
go with with adjustable lowering links and the lowering strap. Being a part-time drag racer, it makes it nice to drive to the track, slam, race, raise, and drive home. You might want to look into an adjustable kickstand to make life a little easier while you bike cools between runs.
blackbullet76
posted January 20, 2007 11:00 AM
K, thanks. I'll go with straps in the front and dogbones in the rear. I think ebay has the dogbones and I think I saw an adjustable kickstand the other day on there.
lietoome
posted January 20, 2007 11:06 AM        Edited By: lietoome on 20 Jan 2007 11:09
not dogbones, but true adjustable lowering links.
I bought mine directly from spencer cycles. The dogbones work, but the adjustables make the ride home much more pleasant----especially on your lowers.
not sure if they are a site sponser, but their customer service is much like Brock's. They also carry a few items for the 14 that are not listed on their site---mirror block offs, etc.
http://www.spencercycle.com/
posted January 20, 2007 05:59 PM
suggestion: do it right and get the rear lowering links and front strap from brocksperformance.com
posted January 20, 2007 06:00 PM
Oh and the Brock's sticker that comes in the box may be good for another 3 horsepower.
lietoome
posted January 20, 2007 06:10 PM        Edited By: lietoome on 20 Jan 2007 18:10
take a look at both sights and compare the prices because the customer service is the same. If you want, I'll sell you my strap and links for 1 Grand
jeepersracing
posted January 20, 2007 08:21 PM
i have a set of muzzy bones in stock for the zx14
  Ignore this member    Click here to visit jeepersracing's homepage.
blackbullet76
posted January 21, 2007 06:36 AM
$1000 bucks! What a deal!!! lol. I check out those sites, thanks!
posted January 21, 2007 11:23 AM
I typically used Brocks not only because they are #1 in customer service, not only do they personally research, race and design products specific for the ZX14, but also notice they also sponcer this site.
blackbullet76
posted January 24, 2007 07:05 AM
Ok, I was wondering. Do I need just the straps for the front or will I need mounting brackets for the straps as well?
posted January 24, 2007 10:20 AM
you can do wihtout, but id strongly recommend getting the brackets. i dont have any bc i took the strap off my 636 and put on it, havent ordered anything else yet for the bike...
blackbullet76
posted January 24, 2007 10:55 AM
Ok, thanks. I want to do it right. I don't want to half ass anything on a bike like this
blue max
posted January 24, 2007 10:57 AM
i do not have the brackets, i went to the fender mount above the caliper, had to get different bolts, gotta lot of clearence for the radiator also
best 9.23
0.2540340423584 seconds processing time
