BIKELAND > FORUMS > ZX-14.com > Thread: looking for stock flys out -map- NEW TOPIC NEW POLL POST REPLY
twisted1
posted January 17, 2007 05:57 AM
Hey Guys!
Just got my 14 last saturday.
Blue ....
So right now it's basicly stock other than I made a blue rear brake line.
Last night I pulled the flys and took the screen off the filter.,,,, at 2am
So have not ridden it yet and of course its raining here now. (florida)
Have a PCIII on order and looking for a stock bike flys out map if someone could share.. it would be greatly appreciated! twisted1@twistedbikes.com
Isn't there a place where we store and post maps so we don't have to mess with each other for something this basic???
If not I have a website... www.twistedbikes.com and could put a link on it for maps....
send them to me and I'll upload to the site ... just a thought...
Thanks guys!
Twisted1
Stalwart
posted January 17, 2007 07:54 AM
Since you already have a PC3 coming, PM zx1kr and buy a map from him. If you had asked about this first you could have saved money by ordering a PC3 from him and had it come with the map already loaded.
Stuart
Ridin' the Trump train.
LandspeedLarry
posted January 17, 2007 08:34 AM
Just go on the Powercommander website. They have a map for the European model with the flys removed.
Home of the World's Fastest Naturally Aspirated motorcycles.
ninja14
posted January 17, 2007 09:41 AM
BUY a map..........there are plenty around and you don't need it anyway. I actually just pulled my PC off when I did my AF tests and ended up leaving it off. I have a few maps if anyone wants one anyway......but the PC is not NEEDED if you do flies and pipes.
havabusa12r
posted January 17, 2007 09:14 PM
maps sent to above e-mail addy
(68 Yam 175 2-stroke)
(99 Copper Busa) (99 Duc 900 SS full fairing) (00 MV Agusta F4S) (02 Aprilia RSV Mille) (02 ZX 12r CTB) (03 KTM 950 Adv)
(04 Yam R1) (05 LE Busa) (07 ZX 14)
BobC
posted January 18, 2007 04:49 AM
There seems to be a difference of opinion on this forum about whether the A/F ratio is too lean or ok with the secondary butterfly's removed. Depends who you believe !
If the engine management system does not achieve a stoichiometric air/fuel mixture but runs lean on light loads then damage will occur sooner or later. I have seen a map showing the ratio off-the-scale on partial throttle before re-mapping with the butterfly's removed, and remember that's the area most mileage is done in.
I can't tell you guys what to do but strongly suggest that if you remove the butterfly's without installing a Power Commander - at least take the bike along to your tuner to get the A/F measured on part throttle.
wrongway
posted January 18, 2007 06:03 AM
the partial throttle for cruising is 10% or less. I dont think that flies in or out change the air flow at this range. To prove this point , look at the maps on the power commander site and compare the map for a stock bike and the euro flies out map. At 10 % they are close. At 20% and up they differ alot.
the comparison I mentioned earlier does show the difference with flies out above 20%. maybe with a TRE the difference would not be as much , since the flies opened sooner?
Roy
BobC
posted January 18, 2007 06:17 AM
Roy
Quite right about the <10% throttle Roy and it's fine at full throttle too but that still means that every time you accelerate on a light throttle, climb a gradient, ride into a headwind or even blip before a downchange the A/F ratio is wrong.
ninja14
posted January 18, 2007 06:44 AM        Edited By: ninja14 on 18 Jan 2007 06:44
I got tired of this subject so I finally tested it myself and got this
Nelson Taylor
posted January 18, 2007 09:56 AM
Thanks ninja14,
good info indeed.
ninja14
posted January 18, 2007 10:47 AM
I put on a wideband as part of my turbo R&D........so I wanted to share the numbers.....hope it helps.....
0.23820805549622 seconds processing time
