BIKELAND > FORUMS > ZX-14.com > Thread: Passport detector mount NEW TOPIC NEW POLL POST REPLY
vegasdude
posted January 03, 2007 06:40 PM
Brock's steering damper is going to utilize the center steering stem where my current radar detector mount is located. Does anyone else have a pic of another solution and where to buy a new mount? Thanks......
zerMATT
posted January 03, 2007 07:17 PM
Techmounts control mount... works like a charm.
vegasdude
posted January 03, 2007 07:25 PM
Perfect thanks!!!!!!
vegasdude
posted January 03, 2007 07:28 PM
Did you use the Tall mount or the regular?
zerMATT
posted January 03, 2007 08:54 PM
Tall. Works fine with Heli Risers too... didn't have to adjust it down at all.
vegasdude
posted January 03, 2007 09:54 PM
That's what I thought. Just wanted to make sure before I ordered. Thanks again.............
posted January 03, 2007 09:55 PM
Wow @ that mount- Will that mount rotate or move into a position that will allow a cam to see the speedometer and out the front such as a tank mount?
zerMATT
posted January 04, 2007 11:50 AM
I don't think a camera will work very well with the control mount. It's VERY close to the faring when you turn the handlebars - my V1 just clears by 1/4" or so.
I used this mount because I wanted my V1 to have an optically unobstructed view of the road ahead to pick up laser well (there's lots of laser around here). A camera might work here, but only if you don't have to turn much, plus, unless it's a very wide angle view, I don't think you'd see the higher 3-digit speeds.
posted January 04, 2007 01:41 PM
OK, thanks~
blitzkrieg
Road kill = Free lunch.
posted January 04, 2007 10:19 PM
The Techmounts are very slick items.
I've got one on my ZX-12R and R1. Well worth the $$.
posted January 04, 2007 10:25 PM
tell 'em yer a member!
vegasdude
posted January 10, 2007 07:11 PM
Got my tech mount in. Works great! Thanks!
zerMATT
posted January 10, 2007 07:35 PM
Beats the stem mount anyday... steering damper or not.
Vegasdude
posted January 11, 2007 02:00 PM
I just noticed that my stem mount is also a Tech mount!
0.30505084991455 seconds processing time
