BIKELAND > FORUMS > ZX-14.com > Thread: Update on oil in airbox NEW TOPIC NEW POLL POST REPLY
heavenlyride
posted December 11, 2006 05:13 PM
Well, the community rules!
The dealer concensus is that the airbox was contaminated by oil from one of two things.
1. Overfill of crank case, likely at start of life.
2. I put it in there. Not as likely.
Any way the solution is to keep the level in check. I will do so from now on.
zx12mark
posted December 11, 2006 10:02 PM
it puked
2togo
posted December 12, 2006 05:52 PM
Having to much oil in the engine will cause this. I do the maintaince on our 14's. When I pulled the flies there was oil in the air box. Klotz. So I know I was the culprit. It didn't come with Klotz in it from the factory. Looked at the level glass and it was just a thick wisker over full. Ditto
ninja14
posted December 14, 2006 04:26 PM        Edited By: ninja14 on 14 Dec 2006 16:31
From the book:
.....so it is expected.
In the canyons I use a lot of throttle braking and RPM's so when the air switching valve opens oil will go in. If you use less throttle braking and at lower RPMs you will get less oil.........or put on the block-offs.
0.22422695159912 seconds processing time
