BIKELAND > FORUMS > ZX-14.com > Thread: ZX11clutch fiber part nbr. for the 14 NEW TOPIC NEW POLL POST REPLY
Denver zx 14
posted November 17, 2006 01:16 AM
I checked Kawasaki's web site for the ZX11 clutch fiber and they show
part nbr 13088-1083 which matches the last set I bought for my 11.
They also show a 13088-1107 for the 2001 D model.
The 13088-1083 is the plate I measured which matches the ZX14 plate in circumferance and thickness. It has almost double the cork material of the 14 plate. I just put a new clutch in the 14(original clutch lasted 25 runs) that I ordered from Schnitz but as well as the 11 clutch lasted,( over 200 runs without failing) I'm going to purchase a set of the 11 plates and swap them out this weekend. I'll let everyone know what I think of the modification for the 14.
posted November 17, 2006 04:16 AM
Dont forget to soak the fibers over night before install...
Looking forward to your updates!!!
speedgene
posted November 17, 2006 05:06 AM
Fully assembled, the friction/steel 'pack' length is:
STD: 53.52 ~ 54.52mm (2.11 ~ 2.15 in.)
To adjust, use:
13089-0019 ~ 2.3 mm (0.091 in.)
13089-0018 ~ 2.6 mm (0.102 in.) (STD)
13089-0020 ~ 2.9 mm (0.114 in.)
Don't use a 2.9 mm and a 2.3 mm at the same time.
E-tard
0.24200105667114 seconds processing time
