BIKELAND > FORUMS > ZX-14.com > Thread: Hooking up a Dyna Shift Light NEW TOPIC NEW POLL POST REPLY
jarhead
posted November 13, 2006 08:58 AM
Hey guys, new to the board. I need a bit of help. I am trying to install a Dyna DSMS 2H shift light on my 14. I have done a few in the past but always went off of the coils. I would like to use the tach signal this time but am having a hard time locating it. I searched the archives and found a bit about tapping into a light blue wire at the guage cluster and did. I have the bulb test light when I turn on the ignition but can't get the light to actuate at the desired RPM. Any help would greatly be appreciated. I have a manual and can't find aything that mentions a tach signal.
ninja14
posted November 13, 2006 10:04 AM        Edited By: ninja14 on 13 Nov 2006 10:06
I use the brown/white wire from fuse box 2 - under the seat on the left - for the signal when I dyno.
Semper Fi
edit............if you are using the TRE 006 it won't work anyway........no signal.
jarhead
posted November 13, 2006 11:18 AM
I appreciate the reply. I am using the TRE, I was unaware the two were incompatable.
Thanks Again
0.39855599403381 seconds processing time
