BIKELAND > FORUMS > ZX-14.com > Thread: How far should I stretch it? NEW TOPIC NEW POLL POST REPLY
nightmare
ACP Racing
posted November 03, 2006 06:12 PM
Well I have been running pretty good but I am getting killed of the line. I just ordered the shinko 200 rear tire and did away with the bt014. This should help me hook up. I have lowered it as well. I am thinking about 71/2 inches. These are the mods, lowered, pc, brocks smeg, and the flies are still in. Smokin or somebody help!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
posted November 03, 2006 07:11 PM        Edited By: smokinZX14 on 3 Nov 2006 19:13
Well remember this the longer it is the easier it is to spin the rear tire ... If you go real long you have to run very little air pressure in the tire and that kills your MPH...At one time i had mine at 5 1/2 over and i think it needed to be shorter....If the track wasn't hooking i could spin in 4 th gear....On the street with a long arm you will never hook it no matter what tire you have ...If i was to make a guess i would say 61 to 62 inchs would be about as good as it gets ,, Now on the tire deal , Brock has gone 9.0s with the stock tire and i have gone just about as fast with stock tire...So i don't understand why your having a problem hooking unless you track is real crap.... Now on to the Shinko tire > it's a heavy ass tire and you have to haul that heavy sucker down the track with you ....Most fast zx14s that have long arms are running a lighter 180 shinko..... So you really don't need a 200 tire...
I have to ask > How fast have you gone ? What kind of 60 foot times are you getting? What air psi in the stock tire? I ask this because i need a base line to help you with your problems.... I will tell you this, if you leave it stock wheel base you will in the long run be a much better drag racer with higher skills ...If you get fast at stock wheel base you will be really fast when you do add more swing arm......Sorry but there is no quick fix to go fast, it takes lots of seat time to get fast ...I just don't want to see you give up to easy on the stock wheel base ...Smokin...
Nelson Taylor
posted November 03, 2006 11:10 PM
I am a fan of stock wheelbase machines
But if you must no longer than 62in
kawasaki_rick
posted November 04, 2006 05:01 AM
Stretch it as far as possible, then put a mickey thompson shootout tire on it. Itl hook at the strip.
nightmare
ACP Racing
posted November 04, 2006 06:32 AM
I have been 9.46 at 149. I have to find my slip to get the 60 time for that run. My psi was down to 15lbs. I don't know if that makes a difference but I only weigh 130. I am ok on the track but it is a pretty shitty track. Ever time i shift to 2nd, she breaks. Also I am not strapped. on a couple of incidents, she has stood up in 3rd. i guess i am ripping the throttle too hard. This only occured when I kind of rushed the bike out of a spin in order to run down someone. The only reason I am stretching it is because. the stretched gsxr1000, and the extended hayabusas are killing me off the line but I am getting lucky enough to outride them and catch'em. From time to time, I get a little to anxious and the bike stands up every gear. once I settle down, I am good. The guy out here that is killing everyone reccommended that I stretch it but it does not need the strap. I dont know about that one but I am learning so I take everything into concideration.
60ft 1.23
8th Mile 5.16
ACP Racing
posted November 04, 2006 10:12 AM        Edited By: smokinZX14 on 4 Nov 2006 10:13
15 psi is why your MPH is down, you should be right at 151 mph ...Sounds like your track is crappy, our track will do that now and then.... You really need a strap and that will stop all that 2 and 3rd gear wheely stuff ... You will be able to launch harder with the strap but it will still wheely in first if pushed to hard ....9.49 is really really good for no strap....Get a strap and i'm betting you knock off a 10th.........If you do add some arm you will pick up 1.5 to 2 tenths easy but you still need a strap ...With the longer arm a strap comes in handy , you can leave it kind of lose if it's not hooking and as the bite comes around you can pull it down and go even faster ..Think of it as a 23.00 dollar tunning aid ....9.49 with no strap and a shitty track you are riding that puppy real good.. smokin..
Ojref
posted November 04, 2006 12:52 PM
How about leaving it alone and getting a sticker tire in the rear? I can launch just fine on a stock wheelbase with a Michelin Pilot Power on concrete or asphalt. It's all in the methodology!
2006 Kawasaki ZX-14 Ninja, Red now with mo' Brock's in my lyfe
1991 Yamaha Vmax - Because I need a mule to carry the manhood
2002 Ford Lightning - Ford GT Aluminum block engined, 802HP 911TQ now WhippleCharged
lucky14
posted November 04, 2006 05:56 PM
Ummmmmmmmmmmmmmmmm.........don't think a stickier tire is gonna prevent the wheelies.
Bently
2012 14r In Blue and no Mods!
posted November 05, 2006 07:31 AM
stickier front tire might! LOL
nightmare
ACP Racing
posted November 05, 2006 04:12 PM
Yeah I was thinking the same thing. Oh yeah, the track really sucks. the shut down area scares the hell out of me but i think I have found another one to attend. Thanks!
60ft 1.23
8th Mile 5.16
ACP Racing
lucky14
posted November 05, 2006 04:40 PM
WHY, oh WHY, didn't I think of this?
I hate it when I miss the obvious..........................
Bently
posted November 05, 2006 04:42 PM
Just trying to Help LOL
FlatoutBu
posted November 06, 2006 03:42 PM
I think this goes back to rider taste....I like my bike stretched. I'm 7 inches over and planning more next year. If you think you have reached your limit on stock wheelbase go longer, or you can add hp or less weight. All will make you go faster you just have to decide which path you will go down.
06 Blue 14
9.008 at 153mph @ 195 suited
nightmare
ACP Racing
posted November 07, 2006 02:04 PM
I decided to lower the front as well and drop two teeth in the front sprocket. so now I am 7.5 inches, 15 in the front and lowered front and back. also some cool looking frame sliders. I will try to post some video or at least some pics.
60ft 1.23
8th Mile 5.16
ACP Racing
0.22919106483459 seconds processing time
