BIKELAND > FORUMS > ZX-14.com > Thread: Free Mod For 186mph shutdown NEW TOPIC NEW POLL POST REPLY
RICH CRAFT 1
posted October 30, 2006 02:54 PM
If you take the front sprocket nut which has 4 corners and ground one of them off this wil reduce your speed by 25%. I tried this saturday at the dyno. I run a 16.48 gears and it pulled 160 mph @ 11000 RPM in 6th gear. If you grind this nut dont take more than the corner off because this causes the shaft to be out of balance but not enough to hurt anything. Also @ 16.48 my speedometer was about right. I wanted to go to the texas shootout last saturday but my work wouldnt allow it. Hoping to go to the PMRA race this saturday at oklahoma city. Maybe ill see if this thing will run 8s.
lucky14
posted October 30, 2006 04:17 PM
Your 1/8th mile times say that you're in the 8's!
Good luck and let us know!
RICH CRAFT 1
posted October 30, 2006 04:50 PM
thanks luckey
1BADZX12R
posted October 30, 2006 05:16 PM
Rich Craft i did almost the same thing on my zx10... My deal was a 12 point socket and rounder the nut down... It reads closer now just haven't tested it against the gps yet.. I figured it would work but wasn't sure
flatoutbu
posted October 31, 2006 08:02 AM
Cool i'll have to try that. Mine shows 180 going thru the traps with 16/44..only going 147-148 though
06 Blue 14
9.008 at 153mph @ 195 suited
flatoutbu
posted October 31, 2006 08:03 AM
Cool i'll have to try that. Mine shows 180 going thru the traps with 16/44..only going 147-148.
06 Blue 14
freddie900
zx 14 2007
posted November 02, 2006 07:56 PM
could you post some pics?
0.26360607147217 seconds processing time
