BIKELAND > FORUMS > ZX-14.com > Thread: mirror block offs installed NEW TOPIC NEW POLL POST REPLY
lietoome
posted October 29, 2006 10:28 AM
installed my red anodized mirror block offs. Made some u-shaped brackets out of some cheap shelf brackets. Painted and mounted to the front screw on the ram tube covers. I'm using the 2" round blindspot mirrors. Had to cut a hole in the back of the mirrors to epoxy a bolt. Test run, they worked great. Waiting for the epoxy to cure, should have pictures tomorrow. They look fine and work great. Less than $10. Used the screw and bolt from the factory reflectors, had some epoxy in the garage and used a dremel , drill, and grinding wheel to make the brackets.
FYI--Dino makes a sweet set of mirrors for the 14. Knowing Dino's reputation, I'm sure they are first rate----and Bolt on.
I'm just cheap and bored, so I made my own.
0.25986099243164 seconds processing time
