BIKELAND > FORUMS > ZX-14.com > Thread: 1/4 mile times for a 335lb rider NEW TOPIC NEW POLL POST REPLY
kawpower
Mr kawasaki 2 you!
posted October 17, 2006 05:32 AM
What do you guys think of my best time so far with these mods on my 14?AreaP 18in 2.5 carbon slipons,16/43, stapped in front cant lower rear it rubs, 3in over ext, orient elect over air shifter, filter in and 91 pump gas, 60ft 1.672 1/8 112 mph ,1/4 10.07 138mph Atco raceway .
halvefast
posted October 17, 2006 05:47 AM
Not bad at all for your size, What were your 330 and 1/8 times?
ECTA Ohio Mile 195.132mph
posted October 17, 2006 05:58 AM
I think you done good for 335 pounds...I bet you are close to 850 pounds total.... Get that 60 footer down to the low 1.60s and you will see 9s ...Smokin..
kawpower
Mr kawasaki 2 you!
posted October 17, 2006 09:23 AM
Here is the run,R/T.117, 60 '1.672, 330-4.309,1/8 6.494,MPH111.85, 1000' 8.416, 1/4 10.073, MPH 135.43 THANXS GUYS.
flatoutbu
posted October 17, 2006 10:19 AM
Sounds about right for a guy your size. I think 9.90's wouldn't be too hard. You could probaly go with more gear and have you tried cranking on your spring? I got mine turned all the way done...so it's as stiff as it will get. Good job!!
06 Blue 14
9.008 at 153mph @ 195 suited
burnout
posted October 17, 2006 11:17 AM
Good job kawpower!
1/8 5.66@129.77
1/4 8.74@159.60
kawpower
Mr kawasaki 2 you!
posted October 17, 2006 11:32 AM
Thanks, i will tighten shock down some to see what happens, it does squat a lot when i launch and the chain skips a tooth or two.
Bently
2012 14r In Blue and no Mods!
posted October 17, 2006 01:01 PM
Good runs, you will get in the 9's
posted October 18, 2006 04:31 AM
THE CHAINS SKIPPIN???????? r u sure? sounds like to me you need to tighten your chain
kawpower
Mr kawasaki 2 you!
posted October 18, 2006 06:17 AM
u wanna check it?
bishopzx12
posted October 18, 2006 06:21 AM
Was it smoky robinson that said i second that emotion vincent.Please check that chain
1996 ZX7R
1999 ZX9R
1999 ZX11
2000 ZX12R 1270
2002 GSXR 1000 "I was Drunk"
2003 ZX12R 1375
2006 ZX14
2012 ZX14R
halvefast
posted October 18, 2006 08:16 AM        Edited By: halvefast on 18 Oct 2006 09:18
I think he is hearing the chain bind on the c/s sprocket.
Kawpower- You are really doing better than I realized.
Here are my best with a crappy 60 ft. :
R/T 60Ft 330 1/8Et 1/8Mph 1000ft 1/4Et 1/4Mph
0.024 1.713 4.353 6.524 113.52 8.411 10.018 140.06
Just missed that 9 sec. pass, better 60's will get it there, I know practice, practice!
Oh and I'm 235 suited, bike and rider 775lbs. bone stk, except -1 c/s
kawpower
Mr kawasaki 2 you!
posted October 18, 2006 09:17 AM
thanx 1/2fast, we and i do mean we check the chain before every run,if rickey g is at the track thursday he will take a look, and we will be video taping the runs at the starting line and focusing on the tire and chain,i run 35lbs of air and no tire spin these stock tires are the sh%t.
flatoutbu
posted October 18, 2006 10:16 AM
Mine does the ol'e chain slapping thing too when it's loose. I'm 7 inchs out and you have to run it pretty tight to keep it from doing that. I think a lock-up will be in your future with a guy your size. I went thru 3 clutchs this year alone. I'm calling MTC next week and putting the order in for mine. The stock tires are the shit...never had a traction problem with mine. i wore it out in 500 miles and threw on a shinko. Just to give you a compairson there is 2 tenths between my cousin and me and he's 60 pounds lighter. Your doing a good job though.....
06 Blue 14
kawpower
Mr kawasaki 2 you!
posted October 18, 2006 11:19 AM
Thanxs flatout, i thought i was the only one that has burnt the clutch out so soon, i am on my third clutch and when i told the guys at the track they didnt believe me until i went in the trailer and got the old ones to show them, i am running Zx11 fibers now and they are holding up well.
Nukedog
posted October 20, 2006 04:53 PM
I've had chain skip before on my Busa. it is actually fairly common when you go -1 on the front of a bike and you make good rwtq...
02 Busa...Turbo...
09 YZF-R6S...
flatoutbu
posted October 23, 2006 10:44 AM
Are the zx11 fibers any cheaper then the 14? Are the pads on the fiber wider or are they the same?
06 Blue 14
kawpower
Mr kawasaki 2 you!
posted October 23, 2006 11:03 AM
All things considered yes they are cheaper but thats up to who u buy them from, and yes the contact pads are larger and the plates are not wide enough to worry about stack height.
flatoutbu
posted October 23, 2006 11:09 AM
I replaced all the fibers in mine with that one large one in the basket....the very first one you see. I took all the ones in the middle out and used all the larger pad ones. They seem to bite alittle better and i shimmed the springs...140 thou...
06 Blue 14
kawpower
Mr kawasaki 2 you!
posted October 23, 2006 02:08 PM
Why didnt u just buy springs, all the 14's that are running here have race springs in them and the riders seem to like it.
posted October 23, 2006 03:17 PM
kawpower, nice meeting you at Englishtown!!!
When you going to put a new spring on that badboy or change the shock to a Penske or Ohlins???
kawpower
Mr kawasaki 2 you!
posted October 24, 2006 04:05 AM
It was a pleasure to meet the famous CrotchRocket, MAN U RIDE THAT BIKE. Rickey G has a shock he wants me to try out, since i will only be att, the wally at cecil, the shock will be changed this winter .
flatoutbu
posted October 24, 2006 06:48 AM
I done this waaay before they had springs out....and the 25 cents i spent on washers work just as good. Alot of stuff i did to my bike was back in June when i got the bike. Wasn't anything out for it in the aftermarket.
06 Blue 14
0.29146313667297 seconds processing time
