BIKELAND > FORUMS > ZX-14.com > Thread: brock-hindle question. NEW TOPIC NEW POLL POST REPLY
kawasaki_rick
posted September 22, 2006 06:42 PM
I just got my B\H system on . I bought a p\c with the map installed for the pipe and no flies. Im wondering if the map was for baffle in or out? Or does this matter. Also im wondering if they want u to take the air filter out? Just 2 add it was a breeze 2 put on. The only problem i had was was with the p\c, turned out 2 be me not knowing alot about bikes. thanks for every1s help with that on here. I wouldnt know what 2 do without this board.. thanks
Bently
2012 14r In Blue and no Mods!
posted September 22, 2006 07:24 PM
Do not run with the air filter removed on the street, only at the track. There is a track map from Brock that is set up for the air filter out, and it does make more power. I see about a tenth and 2mph with the filter out and track map in.
flyboy
posted September 22, 2006 07:32 PM
Go the Brock's site get into the map section. Open it up and if you can't figure out the codes, open up each map and it is printed in plan english at the bottom.
posted September 23, 2006 08:10 AM
The default map that Brock's ships PC's preloaded with is for stock bike flies in. I put a laptop on mine and verified it was correct after I did my install. Also, if you look on the back of the PC- they place a sticker on it and write the map details and date it was loaded for you.
My gen3 is carbon, I never looked into baffles-out mode and can't offer details.
kawasaki_rick
posted September 23, 2006 01:32 PM
I had it set-up for the smeg system with flies out. I just drag race it so im gonna pull air filter out. Gonna leave the baffle in. powercommander says on the back bpp-zx14-06-smeg B-u-track no sec map1.djm.
0.26119208335876 seconds processing time
