BIKELAND > FORUMS > ZX-14.com > Thread: Quick Shifter NEW TOPIC NEW POLL POST REPLY
tomslick34
posted September 03, 2006 09:03 PM
Quick Shifter
I have the PC 3 and want to get the the Quick Shifter, can someone tell me how this works when you shift in neutral? I had SWOL on my ZRX and I used the clutch lever switch to shut the unit off, is there something like it when installing the Quick shift? if it is in the software how dose it work, do you have to set it every time you shut the bike off? Thanks for the Help
  Ignore this member    Click here to send Tomslick34 an AIM message.
posted September 03, 2006 09:07 PM
The quickshifter interrupts the fuel? ignition? for a adustable period of time, unloading the transmission and allowing an clutchless upshift. You still have to move the lever. It's not an airshifter.
tomslick34
posted September 03, 2006 09:14 PM
Thanks swft, I under stand that it's not an airshifter. I want to know how it works when you come to a stop. Each time up pull up on the shifter the quickshifter cuts the engine in some way. That said what happens when you want to put the bike in neutral.
posted September 03, 2006 09:35 PM
Oh, sorry for my misunderstanding of your question. The quickshifter only functions on upshifts from 1st. Should you roll up to a light in first, the kawasaki positive neutral finder function will put the bike in neutral, and I *think* the quickshifter will still cut the engine for a second, but not sure on that one. But let's say you are downshifting from second, the quickshifter won't do anything for your downshift.
That make sense?
tomslick34
posted September 03, 2006 09:53 PM
Thanks again Swft. I understand how it works, I guess I'm looking for more of an install thing. The DynaJet web site is a little vague on the install Instructions. Anybody have the Instructions on how the wire the thing up and or how it interfaces with the PC3?
zxlnt
posted September 04, 2006 04:11 AM
It plugs into the expansion port on the PC3 USB's. Load the software on your computer and set the kill time and rpm range you want to shifter to activate and send it to the Power Commander...
Bently
2012 14r In Blue and no Mods!
posted September 04, 2006 06:44 AM
I took me less then 1/2 hour to install and it works flawless. I would never mess with all the airshifter bottles and lines etc. for how good the quick shifter works. I love it at the track. have ran 9.48 with it and I'm over 235 suited.
tonytooth
posted September 04, 2006 07:21 AM
Can we use the quick shifter on the zx14? I have a friend who uses it on his 04 gsxr1000 but I tried to get it for my 06 gsxr1000 and it would have cost me a lot more money because I needed extra stuff because the ignition system was different.
Is anyone here running it on there zx14 and is that all you had to buy to be able to use it? Thanks.
MySpace
  Ignore this member    Click here to visit tonytooth's homepage.
Bently
posted September 04, 2006 08:11 AM
Yes In the above post I'm talking about the install on my 14. it works great
tonytooth
posted September 04, 2006 08:30 AM
Great, I may have to buy that too. More money out the window. That should make the imitation wife happy. ;0)
MySpace
nightmare
ACP Racing
posted September 04, 2006 11:05 AM
where did you get it from and what was the cost of you don't mind me asking?
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
Bently
posted September 04, 2006 11:23 AM
Orderd it from my dealer, think it's around 240.00
tomslick34
posted September 04, 2006 01:22 PM
Did I get hijacked?
Zxlnt, thanks for your helpthat was what i was looking for! No cutting apart the loom...!
Bently, any photos of how you mounted the sensor?
Thanks,
TD
zx1kr
posted September 04, 2006 01:39 PM
I have the PC3 QuickShifter that has to be mounted to the shift lever(as opposed to the H-bar mounted button) I assume that is the one we're talkin' about? I'm gonna mount as soon as my 16T Sprkt comes in. I'll get some pics posted when I get it on.
tomslick34
posted September 04, 2006 01:40 PM
Yep, thats was i want to see.
td
lietoome
posted September 04, 2006 06:27 PM
Is the DJ shifter the same for a zx12 and 14? Or can I buy one that came off a zx12 and make it work?
thx
L2M
zxlnt
posted September 04, 2006 06:40 PM
Well the 12R has the pressure sensor mounted in the shift rod linkage, and I dont know off the top of my head if its a pull or a push sensor. I would hazard a guess though that it could be made to work if its a push sensor...
Bently
posted September 04, 2006 06:51 PM
I can try and post some pictures of mine tommorrow
tslewisz
posted September 05, 2006 06:16 AM
Use part 4-104, same as for a Busa.
Ended up moving the shifter attachment point further forward to reduce travel. Mine was cutting the ignition after some "normal" shifts. Seems to be working fine now.
Bently
posted September 05, 2006 06:24 PM
No need for me to post pictures now, that's exactly how mine looks.
0.32813096046448 seconds processing time
