BIKELAND > FORUMS > ZX-14.com > Thread: painting headers? NEW TOPIC NEW POLL POST REPLY
lietoome
posted August 31, 2006 01:25 PM
painting headers?
I've used the hi-temp flat black paint before on my mid-pipe for the 12. It worked well and has lasted for 2 years now with no ill effects.
Any input on what type of paint will work better for the headpipes? I know the headers are a hella lot hotter than the mid-pipe. Any suggestions on what will work better than the BBQ paint? VHT? Or the paint used to paint the header wraps?
Not interested in the jetcoating or anything like that.
Vegasdude
posted August 31, 2006 01:29 PM
On high speed runs the head pipe will turn red hot and start glowing. Perhaps ceramic coating is the only one that will hold up.......................
posted August 31, 2006 01:41 PM        Edited By: dubious on 31 Aug 2006 15:27
Ceramic, is the way to go.
High temp bbq paint will withstand the heat, but will look like shit the first time the hot pipes get wet, and cannot be claened up, as well rock chips will nock it off.
Don't wreck your new pipe, get it coated!
I rebuilt a wrecked GS1150ef, as a first bike, I painted the V&H megaphone that was on the bike, and it still looked like shit.
This was years before Ceramic was available.
Trust me. Ceramic is THE way to go if bare metal is not your thing.
iflyphi
posted August 31, 2006 01:52 PM
What's it cost to ceramic coat a header?? Who does it??
posted August 31, 2006 02:12 PM
Jet hot is national coater, check your local listings ...
Price varies but for best performance and looks, have the inside and outside coated
countersteer
Didn't read the owners manual
posted August 31, 2006 02:20 PM
ceramic coating is the *only* way to go
i wish i had done that to my headers on the zx-12 when i first got em
i plan on ceramic coating any exhaust i get for the zx-14... it can be done in different colours- even kawasaki green-ish or "chrome" look.
definetly dont use any of that resin based high temp engine paint crap on your motorcycle unless its a suzuki.
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
blitzkrieg
Road kill = Free lunch.
posted August 31, 2006 03:31 PM
Definitely don't waste your time painting the headers.
If you Jet-Hot, make sure you search out a good shop and talk to people who have used them.
I've heard a few horror stories (not the norm, but does happen) where items like header-to-collector flanges were sprayed, etc...
And just like powder coating, don't make ANY assumptions as to the applicators ability to know where you do and where you don't want sprayed. Mask the shit out of everything that is NOT to be sprayed.
fastestbusaaround
I eat Fish...
Ceramic coating should also reduce heat to the rider from what I understand...keeps the heat in and pushes more out the back...
FYYFF!!!
posted August 31, 2006 04:15 PM        Edited By: dubious on 31 Aug 2006 17:17
10-4. FBA
and yes... good point
Make sure any mating surfaces, slip fit swedges etc are not sprayed .
you'll never get them together
basically you'll need to assemble the pipe on the bike and mark with a felt marker, where everything fits, so the coater will know what does, and does not get sprayed.
ZX-XIV
posted August 31, 2006 10:05 PM
If you want the best coatings go to www.hpcoatings.com Thjey have been doing drag racers to NASA spacecraft coating for years. Not cheap but the very best...
Rajun Cajun
posted October 03, 2011 04:37 PM
Oh YEAH! Cramic coating and insulating your air box! What a beautiful combination!
Candy Thunder Blue 2006 ZX-14, +1 rear, RoaringToyz blocks, windscreen spikes! (VERY SHARP! DO NOT TOUCH!!!!)
Time lost can not be retrieved! Its not dumb to ask questions. Rajun Cajun
Seven
posted October 04, 2011 06:57 PM
Think i ended up paying about $230 for my ceramic coating for my sidewinder. After I spend $50 at JEGS for the exhaust wrap and its the way to go. They sprayed my fit area on my headers and i had to use a flapper wheel to remove the coating to get the pipe together. Hope this helps!!!
project in the works!!! +4 mil stroker falicon rods CP pistons, APE valve springs, head studs, high pressure oil valve, muzzy HD oil pump plate, Adams performance 2" pan and Tsukigi sidewinder, lowered 2"
Seven
posted October 04, 2011 07:03 PM
Photobucket
Seno
BANNED FOR LIFE!
posted December 04, 2011 01:04 AM
Sorry to bring up an old topic but I found this thread while trying to figure out if it makes sense to coat a Titanium header. I have a Brock's CT on order (coming in Monday or Tuesday) and was wondering if it makes sense to coat the header. I know Titanium has much more corrosioin resistance but will coating it be a waste of $$$ or will it help preserve it ? I am not too worried about the heat on the new 14 due to the dual fans and will be running a fan switch.
VINCE12
Designated Drinker.
posted December 04, 2011 03:40 AM
I thought you should never coat ti? Maybe you can coat ti but never use header wrap? Sorry I know that's no help.
BTW, I'm thinking of getting the CT also and would really appreciate a write up with pics and stuff to get an idea of the fit on the new 14R.
2012 Metallic Spark Black ZX14R
Seno
BANNED FOR LIFE!
posted December 04, 2011 06:34 AM
Sure will Vince... Wondering when the 14R picture thread is going to start actually. Next week my exhaust, lines and undertail will be installed then I will post.
0.25958299636841 seconds processing time
