BIKELAND > FORUMS > ZX-14.com > Thread: Won't start NEW TOPIC NEW POLL POST REPLY
dwzx14
posted August 25, 2006 06:45 PM
Won't start
I Stopped at a MAC machine to get money today. I left the key on and fan run for a minute or so and when I pushed start it turned over for a split second and then started clicking. The temp. gauge was flashing from top to bottom and was making a noise too. I had the wife bring some tools out and I checked the fuses and battery connections. Everything was good. I noticed the voltage was at 11.0 v after a few false starts. It dropped to 9 then I had to go get my truck. Even after it cooled down it was clicking.
It is late and I figured I would ask the "experts" what they think it is before I take it to the scary dealership.I would rather fix it myself if possible. Maybe a bad battery?
zxlnt
posted August 25, 2006 06:54 PM
Sounds like your battery shot craps. The low voltage reading on your Voltmeter is pretty much a dead give away. I
zerMATT
posted August 25, 2006 06:56 PM
If the voltage is that low after only a few attempts to start, it sure sounds like a bad battery.
How hot was the ambient air temp when you stoppped, and was the engine temp high when you shut it off? I guess there's a *very* remote possibility that the engine seized, but that's unlikely...
Hopefully it's just a faulty battery and the dealer will swap it for a new replacement. The battery on my '02 ZZR1200 went bad after only 6 months. I don't remember what brand it was, but I had never heard of it. The replacement was a higher quality (according to the dealer) Yuasa. That new battery never gave me a bit of trouble in the next 4 years that I owned the bike - and that included many miles in HOT Texas weather.
3Boysand3Bikes
posted August 25, 2006 07:03 PM        Edited By: 3Boysand3Bikes on 25 Aug 2006 20:06
edited... redundant info
dwzx14
posted August 25, 2006 07:17 PM
That was definitely the first place I was going to look. I just did not have time to mess with it in the dark. Thanks
fastestbusaaround
I eat Fish...
posted August 25, 2006 11:21 PM
Bad battery or poor connection to the posts...
FYYFF!!!
mugsymd
posted August 26, 2006 05:44 AM
Tell us what the problem was - and if the battery was the problem
1987 Red/White Ninja 750
1988 K1
1991 FatBoy
2004 VROD
2005 K1200S
2006 ZX-14 - Red
speedgene
posted August 26, 2006 07:27 AM        Edited By: speedgene on 26 Aug 2006 08:28
With the bike running, will the volt meter needle swing from say, 12v to 13 volts or more? If yes, then it's not the charging system? If the needle does not move (at all) on the meter (when you blip the throttle), then it is a charging problem, and your battery suffered for it?
If, on the other hand, it's the battery, and the system is charging like a bandit, then my guess would be a poor battery prep on the pre-delivery? Was the battery charged (correctly) before delivery, or did they wet the battery, throw it in the bike and hand you the keys?
The test on the battery, plus the voltage output on the bike's electrical system should pinpoint where the problem lies?...
Too bad. You qualify for warranty work either way.... good luck at the dealer?
Remember to walk the bike with the writer and document each scratch on the fairing parts. That's how you want the bike returned in said condition. If not, then that's new panel parts for you... out of dealer's pocket! Keep the bike (panels) together, then sign off the bike with the manager before work is started... that should keep them on their toes with your bike in their possession... hopefully?
E-tard
mugsymd
posted August 27, 2006 08:32 AM
Still haven't gotten a clear answer
1988 K1
1991 FatBoy
2004 VROD
2005 K1200S
2006 ZX-14 - Red
dwzx14
posted August 28, 2006 04:37 PM
I dropped it off Saturday morning , they said they would get to it Mon-Tues.
Not real happy, but what could I do.
I wanted to bitch , but then it would be Wed,- Thurs.!
I will keep You posted and thanks guys for the help and support.
DW
BIKELAND > FORUMS > ZX-14.com > Thread: Won\'t start NEW TOPIC NEW POLL POST REPLY
0.25882792472839 seconds processing time
