BIKELAND > FORUMS > ZX-14.com > Thread: Installation of Schnitz PC111usb NEW TOPIC NEW POLL POST REPLY
marco383
posted August 18, 2006 10:12 AM
I bought one of Ryan Schnitz's ZX10R PC111s for installation on my 14, and am just getting around to opening it for the install. There are no ZX14-specific directions included, just Dynojet's original sheet pertaining to the 10R. What all is different between the two bike's electrics?
raptor14
posted August 18, 2006 10:40 AM
There is no difference. The box is the same. I have a ZX10R unit on my 14 which I bought
from Brock. The ground wire should have been modified on the 10R unit. The rpm limits in the map are different, with the ZX10R allowing higher rpm. You will need to obtain a 14 specific map and then zero out all parameters above 11,000 rpm (or is it 11,500?). You can use the installation instructions from Dynojet.
http://www.powercommander.com/maps2/224/pdf/engI224-411.pdf
0.24751901626587 seconds processing time
