BIKELAND > FORUMS > ZX-14.com > Thread: Oh Ya! 9.55 at 149.89 NEW TOPIC NEW POLL POST REPLY
Bently
2012 14r In Blue and no Mods!
posted August 12, 2006 02:49 PM
Well went back out today and finally started getting my act together ran 9.55 at 149.89. Ran 120 and some change to the 1/8. I had a 1.68 60 ft. Let my buddy jump on it who wheighs 22 lbs more then me. I'm 210 unsuited this morning And he is 232. He had a 1.58 60ft and ran a 9.586 at 147 and some change. So now I know if I have a 1.60 60ft I can run in the 9.40s. for those who don't remember my set up I have the Brock Smeg with powercommander, quickshifter and Muzzy lowering links, forks slide up 1.25 inches and strapped. running pilot power rear with 36 psi.
pdonnell
posted August 12, 2006 03:09 PM
I've been to keith code classes and recieved invites to wheelies schools. But this dragging thing is appealing. Any school/class to learn dragging?
I gotta think this experience has to drip down to faster starts on the street. I mean in a pinch yunno. Not that street dragging is legal.
lucky14
posted August 12, 2006 03:14 PM
WOW!!!
I read your post several times and all I keep seeing is "some et" @ 149.89.
That puppy is making some major power for having a pipe and pc!
Yep, keep working on the 60' and you're easily in the 9.4's.
Bently
posted August 12, 2006 03:34 PM
Ya it will go easy 9.40s, now I just need to lose 20lbs!
posted August 12, 2006 04:14 PM
Nice going Bently
What gas are you using???
pdonnell, check out my link below...
Bently
posted August 12, 2006 08:10 PM
CrotchRocket, I got the good stuff, just 87octane pump gas.
posted August 12, 2006 08:13 PM
Nice...just think what your mph would be with mr9
Bently
posted August 12, 2006 08:18 PM
Ya probably around 152 or so I would guess.
posted August 13, 2006 06:05 AM
Nice going Bently ... See i told you.........SEAT time fixes all problem ....9.40s are just around the corner and you don't need to lose 20 pounds to do it !!! This fall and 60 deg temps you will be holding on for dear life...
halvefast
posted August 13, 2006 06:48 AM
Bently still at stk wheelbase? Stk gearing and flies in? WOW!
Let me in on your secret, do you feel the Smeg pipe and PC3 mapped correctly
are a huge part of those kind of times?
I'm trying to get fast enough to run a 9.50 index class, we are the same size,
so it would help to know all you have done or experienced.
I've gotten a few 1.68 60' times already bone stk, just lowered. Consistent 1.72 60's,
so I'm assuming I just need the power to get there now.
ECTA Ohio Mile 195.132mph
halvefast
posted August 13, 2006 06:52 AM
What were both of your 330' times on those runs, meaning you and your buddies?
Bently
posted August 13, 2006 09:39 AM
Halvefast, I am geared stock and stock wheelbase. but my flies are removed. My 330 time was 4.23 and my buddies was 4.18. Thought about going to a 16 tooth sprocket, don't know if that will help much or not. And yes if you want to go 9.50's get the Smeg and powercommander and run Brocks map and you will be there. I also ran with my mirrors on, so if I remove those 150.00mph might have been there. I know now after my buddies 1.58 60 ft I can go 9.40's if not a high 9.30.
posted August 13, 2006 11:14 AM
Bently - sounds like you are cranking pretty good! good luck with your next visit to the strip!
Bently
posted August 13, 2006 11:27 AM
Ya feel pretty good If I get my 60fts down to a 1.60 or 1.58 it's going to fly!
flatoutbu
posted August 13, 2006 12:11 PM
good job!! Wish i could run 36psi..i'm happy with 18....lol
06 Blue 14
9.008 at 153mph @ 195 suited
Bently
posted August 13, 2006 12:13 PM
flatoutbu, your running a shinko right? I don't feel I need that with stock wheelbase.
posted August 13, 2006 12:14 PM
you don't need a shinko with stock wheel base...
Bently
posted August 13, 2006 12:17 PM
That's kinda what i figured smokin, pilot power hooks well, never did a burnout!
flatoutbu
posted August 14, 2006 05:55 AM
yup running a shinko...i noticed after walking on IRP how much my track sucks....were talking about a 50+ year old track with low maintance...wish i could start maintaing it.
06 Blue 14
0.34330701828003 seconds processing time
