BIKELAND > FORUMS > ZX-14.com > Thread: Crappy night at the drags..And a big tank slapper.... NEW TOPIC NEW POLL POST REPLY
posted August 09, 2006 08:34 PM        Edited By: smokinZX14 on 9 Aug 2006 21:35
I could not do anything right tonight ...I added some shims to the clutch springs and that made the clutch touchy...I just could not get the right feel of the clutch and could not find the sweet spot ...My 60 footers were off a full tenth....One run i would wheely and the next run i would bog.... Best i could muster was a 6.21@119.. Worst part was my last run of the night I wheelied hard out of the hole and i must have come down a little sideways ...When i hit ground the bike went into a big tank slapper !!!!!I almost lost it..!!! Or i should say the bike almost lost me...
On the other Hand SteveWFL was getting better with every pass he made on his zx14... Once Steve gets his strap and lowering links he will be going even faster...Good job Steve...
serius blk
posted August 09, 2006 08:44 PM
Theres always next time.
posted August 09, 2006 09:43 PM
gotta take the good with the bad!
it wasn't that bad... recovered from a tank slapper!
Bently
2012 14r In Blue and no Mods!
posted August 10, 2006 04:58 AM
Well I was gonna install my shims before going out Saturday but i think I will wait now.
flatoutbu
posted August 10, 2006 05:51 AM
I like mine shimmed but with stock wheelbase...not sure. I ran alot of pass's lastnight too. best was a 6.05 1/8 9.42 at 147....1.47 60'. was trying hard for that 30 but..... I think i'm going to give my bike more gear. Pulled the front end down just alittle lastnight and never had traction problems at 18psi. Did 1nasty wheelie, pulled the strap alittle more and it was fine.
06 Blue 14
9.008 at 153mph @ 195 suited
posted August 10, 2006 03:58 PM
Lee, you know what to do now right???
Take those shims out and leave it OEM...
bbirdxx2000
posted August 10, 2006 04:14 PM
Did you notice your MPH go up with the shims In
9.96 @ 143 stock with flies removed
posted August 10, 2006 05:41 PM
Yup Rick that's what i'm thinking......
posted August 10, 2006 05:43 PM
No I didn't have any MPH change but i was riding like a moron so it would not be a good test.....
posted August 10, 2006 06:20 PM
Thanks, I'm still real slow but ain't givin' up! Gen3 and PC came in today...I'll look for a strap quickly...
but truth of the matter is with all the negative you mentioned you had going on, you were still among the fastest of the fast out there~!
posted August 11, 2006 05:21 AM
The only thing I would do to the bike Lee, is try the 16 tooth with the stock wheelbase...
flatoutbu
posted August 11, 2006 07:02 AM
Yea i think your going to have to go with a softer clutch set-up stock wheelbase...or you could pull 1 shim out and try .070. I would give it another go...and if you dont like, pull them out.
06 Blue 14
0.31746983528137 seconds processing time
